Hi Everyone
rosswaters
Spokane, WA
I'm Ross and have been using Onkio for 40 years and love them besides a few issues they have with heat related issues.
I bought a Yamaha RX-A2070 the other day used for a good deal and I'm wondering about a few things about it.
My setup is a 7.2.2 and I am running 11 mono 240W amps that are rated at .006 distortion. It sounded amazing with the Onkio a pretty much the same with the Yamaha with each having their strengths and weaknesses. In the next couple days I plan on posting my results and am hoping for suggestions from others if there is a way to correct them. Right now theater sounds better with the Yamaha and the Onkio was way better at music. I tend to spend 90 percent in music and 10 percent in movies.
Anyways, I hope to make some good connections on here and see what others are doing.
Ross
Ross
Welcome to HFV.
If the post / response to you helps in any way, use the 'Like' button which is located at the right hand bottom of the post. This helps to build up positive reputation for the FM (Fellow Member).
Hope you have a great journey here!
All the best!
Ross
Hi Ross, welcome to the forum! Looking forward to your detailed impressions on Yamaha vs Onkyo!
Ross
Welcome to HFV... hope you will enjoy your stay here.
