Advice on speakers
Julie
Norfolk UK
I have narrowed down my choices, but it will be hard to audition all of these. I am moving from older equipment and need to downsize. I currently have Rogers LS8a floorstanders from the early/mid nineties.
They will be paired with a Quad Artera Solus in a fairly large room…..probably not ideally configured, but I can’t do a lot about that. I prefer a balanced sound….not overly bright. Classical/acoustic/folk/soft rock music. Vocals are important too.
Shortlist….I am not up to date with how different makes sound so do shoot me down or suggest different/better. Budget £1000 ish
Triangle Borea br08
Fyne Audio 501
Q Acoustics 5040/5050/Concept 50 (bit of a push financially)
Focal Aria 926
Dali Oberon 5
Possibly a pair of Quads?
What else/what should I drop?
Thanks for your help.
From the list try to audition the Borea BR 08 or its smaller sibling BR 07
The Artera does 75W at 8 ohm and the suitability will depend on your seating position wrt the speakers ie how loud you play music
Maybe you can also consider wharfedale speakers (Evo 4.4). If you have liked voicing of your Rogers, you will find wharfedale to be pretty close with almost similar sound signature.
Triangle Borea br08
Fyne Audio 501
Focal Aria 926
Dali Oberon 5
Rule out focal from list for the genres you mentioned
Triangle Borea br08
Fyne Audio 501
Focal Aria 926
Dali Oberon 5
Since you mentioned fairly large room and speakers which are not bright, you can add Wharfedale Lintons/Dentons to your list for audition. The Denton being a bookshelf may need a subwoofer though.
