Maranz NR1501 Chepest 7.1 HiDef Upscaling amp in grey??
hemantwaghe
Banned
Banned
Hi as per price reported by my bro ( not in hi fi scene) Marantz NR 1501 AVR is available at Alfa ,Vile Parle Mumbai at Rs 25500.
I think it is possibaly lowest price AVR in grey with Upscaling amy HD audio support
In fact US price is US$ 599 !!
Marantz Europe
The profile is too slim,50 W X 7 and like many amps no pre outs or 7.1 In..
IS ANYWHERE ANY HD AUDIO AMP AVAILABLE AT LOWER PRICE??
Marantz Europe
FROM SITE
The NR1501 is the first of a new range of AV-Receivers. It provides the customer full functionality and convenience in a very elegant and low height cabinet design. It nicely fits to the Marantz DVD player or even to a Marantz Blu-ray player as it has decoders for standard resolution and high definition audio like DTS-HD and Dolby TrueHD on board. Video signals connected analogue will be converted to HDMI and for digital sources 4 HDMI 1.3a inputs are available. Hook up the satellite box, your VCR, the DVD, game console or your camcorder and don?t worry which input you have to choose on the TV. The NR1501 will handle all. With the OSD menu and the MRAC auto setup using a microphone the installation is even for the none-technical user quite simple. That?s Marantz combination of sound, design and ease of use.
* 7.1-channel AV receiverin slim height cabinet
* 7x 50 Watts RMS
* Dolby TrueHD, DD+, DTS-HD
* Automatic speaker setup by MRAC
* Built-in FM/AM tuner with RDS
* HDMI v1.3 - 4in / 1out
FEATURES
THX Ultra
0
THX Ultra II
0
THX Surround EX
0
DTS HD Master audio
1
DTS
1
DTS ES ( matrix & Discrete)
1
DTS 96/24
1
Dolby Digital Plus
1
Dolby TrueHD
1
Dolby Digital
1
Dolby Digital-Ex
1
Dolby Pro Logic IIz
0
Dolby Pro Logic, DPLII, DPLIIx
1
Dolby headphone
0
Virtual surround
0
Circle Surround II
0
7.1 Linear PCM for HD audio
1
HDCD Decoder
0
SOUND ENHANCEMENTS
Real full channel power drive
0
Pure Direct
1
Super Ring Transformer
0
Toroidal Transformer
0
EI Transformer
1
Copperplated Chassis
0
D/A conversion 192kHz/24bit
0
D?A conversion 96kHz/24bit
0
DSP 24-bit
0
DSP 32-bit
1
DSP Presision 32-bit
0
HT-EQ / Re-EQ
1/-
ADDC
0
Quad differential DAC
0
Copper systemblock shielding
0
Metal systemblock shielding
0
High Grade Audio Components
0
Customized Components
0
HDAM
0
HDAM cover
M-DAX
0
OTHERS
Audyssey auto speaker setup
MRAC
Yes
Bluetooth A2DP v1.2 receiver
Easy setup
1
OSD
1
GUI
0
Variable Cross Over
0
Videoscaling up to 1080p
0
Video Conversion
1
Line memory
0
Analogue Downmix
0
Multiroom
0
Speaker A/B
0
Lipsync Control
1
Random Tuner presets
30
RDS
PS / PTY / RT
Bi-directional ctrl via rs232
0
IN/OUTPUTS
VIDEO
Composite In/Out
3/2
S-video In/Out
Component In/Out
3/1
gold plated In/Out
0
HDMI In/Out
Multiroom Video Out
AUDIO
Analogue In/Out
5/1
Digital Optical In/Out
2/-
Digital Coaxial In/Out
1/-
Gold plated In/Out
Preamp Out
Main Amp in
Multichannel Input
OTHER
M-XPort
0
Speaker terminals
5x screw / 2x click
Height speaker terminals
0
Multiroom speaker terminals
0
Multiroom D-bus In/Out
0
D-bus In/Out
1
External IR in
0
Emitter Out
0
IR Flasher In
0
RS232C
0
DC-Triggers
0
Front Inputs
Audio
USB Audio
SPECIFICATIONS
Audiosection
Power Output
50W
Signal to Noise ratio
100 dB
Freq response (Analogue)
Freq response (digital)
T.H.D.
Input sensivity
GENERAL
Metal frontpanel
1
Remote Control
RC006SR
Remote type
Pre-programmed
Dimensions
440 x 367 x 105 mm
Weight
8.6 kg
Even i saw this piece and found it interesting. the lower power rating is ok for me, only requirement is it should take on all the decoding business without issue. that was a silver piece. i need a black one.
Hemantji, I was able to listen to this amp in action for both movies and music and I have to say its a very good performer unlike what one may read from the conservative 50wpc specs.
Especially music sounded great on the amp, I was really moved by the way songs with string instruments sounded on it.
If it does HD audio decoding and is available for 25k, thats one sweet deal!
Movies also sounded ok with Paradigm cinema package and also with Mission speakers.
My comman sense saya Marantz 50 WPC = 80 WPC Of Onkyo/Yamaha = 150 WPC of Sony!
Seems damn interesting as cheaper than US price ! Anyone able to trace Dubai or Singapore price?
It doesn't matter if a cat is black or white, as long as it catches mice.:ohyeah::ohyeah::ohyeah:
BTW we now each other and met before right?
Yes, we have met before.
i am looking out for 7.1 for my htpc. scheme is all black so need a black av receiver also.
i almost got into a fight getting a black sugo case sometime back. soon a 5770 gpu will join in new setup in progress.
I inquired prices in Dubai from official Denon & Marantz distributor:
AED to INR @ 12.5 INR per AED and rounded off to nearest 100 INR
Marantz NR1501 - AED 1890 / INR 23600
Denon 1610 AED 1789 / INR 22300
Denon 1910 - AED 2599 / 32500
FYI the standard conversion rate from USD to AED is 3.67 AED per USD.
Hope this helps
Hope this helps
Thanks Maann!!
Pls can you find out similar prices of yamaha and harman amps in same catagory?
There is feeble chance of My mama visiting dubai ( in tour) ,but being hi fi illiterate I think i need to arrange a friend in dubai to get something.....anyway she is refusing it and there is tough task of convencing her to get 2 whiskey bottles!!!:ohyeah::ohyeah::ohyeah:
Thanks Maann!!
No problems hemantwaghe! Let me know the model numbers of yamaha & harman amps you're looking for and I can find out the prices.
hmmm whiskey bottles from dubai duty free eh!! am sure they would be put to "good" use:)
Thank , i'll give ya model nos.....
Yes it will be used for "personnel" good use .....:beer::beer::cheers:
If Alfa is 26500 ,then Just 3 K markup is justified!
BTW there are reasons to believe that big grey operators operate as big dealers in other countries and get volume discounts ...so there procurement cost may be lower...
I am taking time deciding between denon 1910 and marantz NR1501 till i shift to new place, although alfa guy says he may not have marantz in stock when i want.
1910 has in comparision
more power
better video reproduction
black colour
7.1 analog in
dual zone for 10k more.
thekinge,
Thanks for posting the prices. The marantz avr is a sweet deal esp for people with an inclination towards music.
I have sent you a PM, pl check.
