- Joined
- Sep 23, 2007
- Messages
- 3,650
- Points
- 0
Hi as per price reported by my bro ( not in hi fi scene) Marantz NR 1501 AVR is available at Alfa ,Vile Parle Mumbai at Rs 25500.
I think it is possibaly lowest price AVR in grey with Upscaling amy HD audio support
In fact US price is US$ 599 !!
Marantz Europe
The profile is too slim,50 W X 7 and like many amps no pre outs or 7.1 In..
IS ANYWHERE ANY HD AUDIO AMP AVAILABLE AT LOWER PRICE??
Marantz Europe
FROM SITE
The NR1501 is the first of a new range of AV-Receivers. It provides the customer full functionality and convenience in a very elegant and low height cabinet design. It nicely fits to the Marantz DVD player or even to a Marantz Blu-ray player as it has decoders for standard resolution and high definition audio like DTS-HD and Dolby TrueHD on board. Video signals connected analogue will be converted to HDMI and for digital sources 4 HDMI 1.3a inputs are available. Hook up the satellite box, your VCR, the DVD, game console or your camcorder and don?t worry which input you have to choose on the TV. The NR1501 will handle all. With the OSD menu and the MRAC auto setup using a microphone the installation is even for the none-technical user quite simple. That?s Marantz combination of sound, design and ease of use.
* 7.1-channel AV receiverin slim height cabinet
* 7x 50 Watts RMS
* Dolby TrueHD, DD+, DTS-HD
* Automatic speaker setup by MRAC
* Built-in FM/AM tuner with RDS
* HDMI v1.3 - 4in / 1out
FEATURES
THX Ultra
0
THX Ultra II
0
THX Surround EX
0
DTS HD Master audio
1
DTS
1
DTS ES ( matrix & Discrete)
1
DTS 96/24
1
Dolby Digital Plus
1
Dolby TrueHD
1
Dolby Digital
1
Dolby Digital-Ex
1
Dolby Pro Logic IIz
0
Dolby Pro Logic, DPLII, DPLIIx
1
Dolby headphone
0
Virtual surround
0
Circle Surround II
0
7.1 Linear PCM for HD audio
1
HDCD Decoder
0
SOUND ENHANCEMENTS
Real full channel power drive
0
Pure Direct
1
Super Ring Transformer
0
Toroidal Transformer
0
EI Transformer
1
Copperplated Chassis
0
D/A conversion 192kHz/24bit
0
D?A conversion 96kHz/24bit
0
DSP 24-bit
0
DSP 32-bit
1
DSP Presision 32-bit
0
HT-EQ / Re-EQ
1/-
ADDC
0
Quad differential DAC
0
Copper systemblock shielding
0
Metal systemblock shielding
0
High Grade Audio Components
0
Customized Components
0
HDAM
0
HDAM cover
M-DAX
0
OTHERS
Audyssey auto speaker setup
MRAC
Yes
Bluetooth A2DP v1.2 receiver
Easy setup
1
OSD
1
GUI
0
Variable Cross Over
0
Videoscaling up to 1080p
0
Video Conversion
1
Line memory
0
Analogue Downmix
0
Multiroom
0
Speaker A/B
0
Lipsync Control
1
Random Tuner presets
30
RDS
PS / PTY / RT
Bi-directional ctrl via rs232
0
IN/OUTPUTS
VIDEO
Composite In/Out
3/2
S-video In/Out
Component In/Out
3/1
gold plated In/Out
0
HDMI In/Out
Multiroom Video Out
AUDIO
Analogue In/Out
5/1
Digital Optical In/Out
2/-
Digital Coaxial In/Out
1/-
Gold plated In/Out
Preamp Out
Main Amp in
Multichannel Input
OTHER
M-XPort
0
Speaker terminals
5x screw / 2x click
Height speaker terminals
0
Multiroom speaker terminals
0
Multiroom D-bus In/Out
0
D-bus In/Out
1
External IR in
0
Emitter Out
0
IR Flasher In
0
RS232C
0
DC-Triggers
0
Front Inputs
Audio
USB Audio
SPECIFICATIONS
Audiosection
Power Output
50W
Signal to Noise ratio
100 dB
Freq response (Analogue)
Freq response (digital)
T.H.D.
Input sensivity
GENERAL
Metal frontpanel
1
Remote Control
RC006SR
Remote type
Pre-programmed
Dimensions
440 x 367 x 105 mm
Weight
8.6 kg
Marantz Europe
Marantz Europe
FROM SITE
* 7x 50 Watts RMS
FEATURES
THX Ultra
0
THX Ultra II
0
THX Surround EX
0
DTS HD Master audio
1
DTS
1
1
DTS 96/24
1
Dolby Digital Plus
1
Dolby TrueHD
1
Dolby Digital
1
Dolby Digital-Ex
1
Dolby Pro Logic IIz
0
1
Dolby headphone
0
Virtual surround
0
Circle Surround II
0
1
HDCD Decoder
0
SOUND ENHANCEMENTS
0
Pure Direct
1
0
0
EI Transformer
1
0
0
0
DSP 24-bit
0
DSP 32-bit
1
0
HT-EQ / Re-EQ
1/-
ADDC
0
0
0
0
0
0
HDAM
0
HDAM cover
M-DAX
0
OTHERS
MRAC
Yes
Easy setup
1
OSD
1
GUI
0
Variable Cross Over
0
0
Video Conversion
1
Line memory
0
Analogue Downmix
0
Multiroom
0
Speaker A/B
0
Lipsync Control
1
30
RDS
PS / PTY / RT
0
IN/OUTPUTS
VIDEO
Composite In/Out
3/2
S-video In/Out
Component In/Out
3/1
gold plated In/Out
0
HDMI In/Out
Multiroom Video Out
AUDIO
Analogue In/Out
5/1
2/-
1/-
Gold plated In/Out
Preamp Out
Main Amp in
Multichannel Input
OTHER
M-XPort
0
Speaker terminals
5x screw / 2x click
0
0
0
D-bus In/Out
1
External IR in
0
Emitter Out
0
IR Flasher In
0
RS232C
0
DC-Triggers
0
Front Inputs
Audio
USB Audio
SPECIFICATIONS
Audiosection
Power Output
50W
100 dB
T.H.D.
Input sensivity
GENERAL
Metal frontpanel
1
Remote Control
RC006SR
Remote type
Pre-programmed
Dimensions
440 x 367 x 105 mm
Weight
8.6 kg
