New(s) for PS3 Users
shailenderb
Firmware ver 3.3 (now available on Sony site) allows Bitstreaming of
BD audio - with two options available:
1. Bitstream (Direct) - Set to output audio with the original digital
signal prioritized.
2. Bitstream (Mix) - Set to output audio that is first mixed with sound effects
such as button sounds and then converted to bitstream format.
I am not sure what is Option 2 above.
The new update also comes with Support for 3D stereoscopic games, if you
have a 3D enabled TV.
There are other updates regarding Tropies etc which I am not interested in.
For info of those interested.
Regds / Shailender
does it mean that even phat ps3 can now bitstream audio?
Option 2 is - there are some sounds that the ps3 produces over and above what is there in the movie/ music. These sounds are alerts, button press beeps etc. If you select option 2, then you can hear those sounds too on your speakers.
1. Yes
2. Thanks for clarifying.
Regds / Shailender
Aahaa, good news, well kind of. But also remember that if you upgrade then you'll loose install other OS option. But I guess that's ok for most of the people.
Didn't geohot hack it. I believe he released his own OS.
I'm not sure if Bitstreaming works on the phat PS3. Supposedly the HDMI chip in the phat did not allow it.
