BlueRay Player w supports MKV file playback thru USB
arnab_d
Gurgaon
hi
Looking for a tip on a BDP which can meet the following requirements.(apart from the usual BD disk support ofcourse)
1. playback MKV files with HD video and DTS audio stored as files on HDD and connected thru a USB on the BDP.
1.a ability to play formats like MPEG HD and AVCHD other HD format would be great as well.. but at minimum MKV.
2. Has 5.1 or 7.1 Analouge RCA output
3. When I play the MKV files, the HD video should be output via the HDMI out and the 5.1 Audio should be output via the RCA analogue out jacks.
Any pointer would be appreciated.
Thanks a ton.
It seems the LG BD 370 or LG 390 are exactly what I am looking for.. MKV support + 5.1 and 7.1 RCA out. BUT does not seem to be available in India.. wonder if there is a plan for launching it in India or buying it online with Warranty...
thanks
thanks
The LG BD 370 IS available in India for Rs 16,000/- odd. The BD 390 isn't available in India.
Thanks.. I checked their web site in india and it was not there so I assumed its not yet launched.. Is it available through their showrooms or online .. pl do give some pointers..
thanks once again...
Good question.
Does anyone own the LG BD370 or LG BD 390?
Can someone confirm if I am playing a MKV file which has DTS audio track, then will the LG BDP output 5.1 audio on the RCA analog out,
or it will output 5.1 audio only on the optical/coax out ,
or it won't output 5.1 at all and do only downmixed L+R on RCA as well as Coax/Optical.
Thanks a lot for the info.. before making a hefty investment in the BDP I want to be sure I can enjoy 5.1 from my MKV rather than mere 2 channel
