sbfx
Hello! Everyone,
I'm writing this article as I believe there others like me who would have suffered or are suffering from HUM, BUZZ and static noises from other devices in their house coming into their hifi setup's.
Firstly I would like to thank Indian_Ears to help me though every step for resolving the issues and helping me understand better the issues I was facing.
Full full setup is Tubes! [Amp and Pre-Amp] Amps are 845 based and are very susceptible to RFI.
The problem;
1. Cable Box: when even I started my system and the cable was connected on the set-top box I got a HUM from my speakers also when I disconnected it, it was softer but still there.
2. Whenever someone rang the door bell, started the tube light or fan there would be feedback from my speakers!!!
To being with I tried all possible "Audiophile power boxes" Pure Power 2000 which is a AC regeneration box and supposedly gives the best possible power but it couldn't help me eliminate the problem.
I used the Acoustic Revive Ultimate power box but nothing no respite it couldn't contain the faults.
Used Isolation Transformer's and Stabilizers...........
The above devices worked but not to correct faults but change the sonic signature of the setup.
I finally started looking at industrial grade Filters and stumbled upon a 30AMPS Single Phase RFI filter from Elcom, I have a direct line coming in from my Meter-room to my audio setup.
I connected is filter right next to my mains near the system this completely cured my problems of RFI (noise) pickup from the tubes, door bell......
But there still was a HUM so after consultation with Indian_Ears I floated the ground of my setup, i.e. cheated all the grounds except the pre-amp, so in essence the pre-amp is grounding all other gear in the chain.
After everything in place it has played absolutely silently!!! no issues what so ever, there was a small click from the fan which was taken care of by installing a small snubber on the fan switch!!!
This has been a superb learning curve for me and the whole project cost for me less than Rs. 2000/- all expensive gear did play a role in changing the sound but not the problem. This has been the cheapest audio component I have in my setup but the most important non the less
Best Regards,
Satyam Bachani.
The problem;
Best Regards,
Satyam Bachani.
