samson cj
Nice review Venkat Sir!! your note on Coimbatore makes Coimbatorian's proud
Thanks for the lovely review, Venkat. It was well written too, I should add. If I understand it right, these speakers do not work well with the normal Amplifiers or Receivers that we folks here use, is that correct?
Regular amps most of us use are voltage drive design. Speakers we use are designed to accept voltage drive as well. Voltage drive designs fundamentally cause distortion to take place in the voice coil. A current amp offers the most precise way to send current through the voice coil without distortion as it ignores the resistance and reactance of the wires, voice coil etc. With proper design full range high efficiency drivers can be use this current very well to deliver great sound.
Audire speakers are based on full range single driver design. Audire speakers have no separate tweeters, mid range and bass drivers and the corresponding crossovers - just a single full range driver - which are best driven by current drive amplifiers. I may be wrong here but thats what I think they are doing.
Just a few points, if I may, please, for Audire speaker reviewer...
Sharath/Audire said:We would like to make it abundantly clear that as a company we highly respect the point of views of all people who show an interest in us. Mr. Murali's comments on the importance of measurements and related sciences is well received and we appreciate him for his thoughts. In fact, as a company, we have been spearheading numerous conventional sources of audio reviews in India to adopt a more scientific approach than what currently exists, including the plotting of graphs for frequency response, phase coherence etc. We will be referring to this in context with our own speakers.
As we make single driver loudspeakers,I'll provide a brief of time alignment and phase coherence with respect to single drivers. We time-align our speakers by design by using extensive fast fourier and time domain theory calculations.
TIME AND PHASE COHERENCE
Time&Phase Coherence can be defined as the state in which two signals maintain a fixed phase relationship with each other or with a third signal that can serve as a reference for both.
The importance of phase response in the audio chain has been brought to greater focus recently by equipment claims of phase coherency, What such claims refer to is that the output signal has the same phase relationships as the input signal. It is not particularly obvious that two different frequency components of a signal can go into a device at precisely the same time and emerge at different times, but it is extremely common.
All audio components distort the phase of the signal to some degree. Even even air alters the time alignment of a signal. The biggest offenders are loudspeakers and their crossover networks. Phase shifts in the audio signal destroy the wave shape of the important attack characteristics of many instruments and hamper our ability to perceive the localization of the image,smearing the apparent source. They can change the steady state waveforms of vocal sounds so that the singer seems to be ten feet wide.
Historically, the phase integrity of the audio signal has been considered much less important than amplitude and harmonic/inter-modulation distortions. As more of those problems are solved and the quality of reproduction improves, phase distortion stands out in greater relief. The question of the audibility of these distortions has become the object of heated discussions regarding the perceivability of absolute phase. frequency dependent phase shifts, and the rate of phase shift. Nonetheless we know that the ear is sensitive to phase and uses phase cues to help determine directionality. We believe that proper attention to phase does produce better sound.
MULTI DRIVERS
The rationale is coherence. It is incredible that so many audiophiles accept the multi-way speaker paradigm without even a microsecond of critical thinking. With most multi-way speakers, I'm tempted to push the eject button on my listening seat. Think of what is involved here - chopping up the music into two or more ranges via a crossover network, feeding each portion to its respective driver - all with the fond hope that the sound radiating from several points in space will somehow integrate into a musical whole. Often this just doesn't happen.
Multiple drivers produce individual wave fronts which are mostly out-of-phase with each other, whose phase-coherent lobes require that the listener sit in a specified position with respect to the speaker placement ("head in a vice"). In addition, crossovers introduce phase anomalies which prevent true and accurate phase coherence in the lobes themselves, whether or not the listener is in the optimum listening position.
The fundamental problem of lack of phase coherence in multiple driver loudspeaker designs causes several types of insoluble problems, the most important of which is loss and corruption of information between the program material and the listener's ears. The types of information which are lost and corrupted includes spatialization and localization information, micro-dynamics, and acoustic harmonics
The crossover is used to split the frequencies which shifts phase and then designers try to compensate with extensive crossover design and tend to forget the basic insertion loss which cannot be avoided .
SINGLE DRIVERS
Single drivers have a single radiating and single voice coil for entire spectrum of sound. This makes them phase coherent by design .The ability of low-mass single drivers and low-mass voice coils to respond immediately to the faintest performance nuance in a phase-coherent manner enables the listener to hear a true and detailed presentation of every instrumental or vocal performance.
We are also sending, herewith, to our good friend Venkatcr, a frequency response graph for the IO horn system that he had listened to on his visit here. So there shouldnt be any problem in cross referring to that.
All tests, plots and measurements of this kind are done in an anechoic chamber. The relevance of such data in real life circumstances (unless you would be listening to your speakers in an anechoic chamber) would be highly questionable.
With the question of flat frequency response, it is wrong to suggest or derive that flat frequency response is a measure of speaker performance. In your example, Murali, you quoted a speaker (B&W 801) with a flat frequency response that is quite impressive. There is another company, by the name of YG Acoustics, the most advanced loudspeaker on the planet. If you happen to chance their website you will learn that YG claims to have the most flat of all freq. response graphs worldwide. While the manufacturer of these speakers is strictly scientific in his approach to speaker design, any review (by qualified reviewers or listeners) will guide you to the realization that his speakers are in no way musically spectacular. Even YG acoustics claim that their speakers image and are as coherent as single drivers, which is unknown in the multi-driver environment. This is something claimed by the most advanced multi-driver company on the planet.
