problem with lg bd550
Does this LG player support MKV files with DTA MA and True HD recording through HDD via USB?
I've tried and it does not support lossless format but rather plays it as ordinary DTS format. Even the WD media player does not support DTS MA or True HD.
In such case, buying this BDP @ Rs.5000/- is better than a Media Player? Does it play Flac?
Buy a BDP only if you want to watch Blu-Ray disks. If your main source is downloaded files, then a media player is your best bet.
WD player and most Media players plays FLAC but sound quality is not good. You would need DAC for excellent output for FLAC. As baijuxavior mentioned BDP is required only if you would like to play Blu-ray disks and if you can afford to buy them at regular intervals, otherwise a Media player is the best option for downloaded files.
