sam9s
- Joined
- Aug 25, 2009
- Messages
- 5,239
- Points
- 113
Guys time to update ....... added another feature .....
1. To be able to boot/power up my my HTPC from remote/on my couch, rather than hitting the power button.
This can be achieved using a very nifty utility called Remote Launcher ...... basically its a tool that enables you to launch applications remotely on your PC via your Android phone. There are other loads of similar applications that do the same, but what I found with this one was the "Wake ON Lan" support, plus the interface is neat and it actually works like a charm.
Few things that needs to remembered is your hardware should support WOL which in today's scenario most of them do. Second your PC should be in hibernate mode. Third your network should have a static IP. To make it work just put the IP of your HTPC/LAN Card and the MAC address of the same, and that's it. Press WOL button on your android application and it powers on your machine right from your couch ....
. Check out a small video I prepared to show you the same .....
[YOUTUBE]http://www.youtube.com/watch?v=kMzaH3bvZm8&feature=player_embedded[/YOUTUBE]
