How to buy a region 'A' 3D Blu Ray Player
krishpiscean
Hyderabad
Any pointers on how to buy a 3D BD with region code A in India or any region free 3D players available.
What I can think of is
1. Request sm1 to get from US etc but not possible in near future
2. Ship from Amazon,guess wd be expensive
Any ideas, pls share
Budget max 20K
TIA
AMZ is shipping BD players directly to India.
Shipping via amazon cost only $22 +.and varies on the model and price of the player + weight.
Cheaper as of now is Panasonic DMP-110 which will workout to $112.
Please note that if you purchase thru shop your world or 20north also, the price will not exceed 10K.
You can try ebay panasonic 3d blu-ray player | eBay
Panasonic DMP-BDT210 - Wi-Fi 3D Blu-Ray DVD Player | eBay
Panasonic T210 is a new 3d player. You can make it region free by upgrading to enhanced firmware.
For items from US, you will also need a step down transformer.
Prices are expensive buddy. Try 20north and try AMZ direct purchase.
thru 20north : DM210 : Rs.10978 ( declared as gift)
Thru 20north : DMP110: Rs.8905 ( declared as gift)
From all the above, buying directly from AMZ is cheaper:) Still you will save another 1K to 2k:)
Both these players along with 310 hold very high regard on US/UK forums. 20north or AMZ + Aramex might turn little cheaper if Customs can consider it as gift.
I completely forget abt step down transformer, that's a hassle i need to consider/ May be I should also check Singapore/Malaysia to save on step down cost.
BTW, which is the best 3D BD player, if it provides good features, I don mind increasing my budget. Don't want oppo and such heavy ones.
Thanks buddies for your replies
The amazon price you quoted is really low. Actually by the time I posted my reply, you had already posted the amazon link. That is the reason why I ended up posting the expensive ebay link.:D
Please also check if the Region A Panasonic DMP-BDT110 and DMP-BDT310 are compatible with 50 Hz content before ordering. The DMP-BDT210 is not compatible. This means that it will not be able to play 1080i50 content (e.g. Planet Earth - Special Edition UK version) even if the discs are region free.
Search before you suggest, i always try to give an lowest/cheapest suggestion(advice giving is easier and free- so lowest) :p
How much does the custom firmware cost? Did any one modify their Pana bluray with the custom firmware?
Please give your feedback
