Hi miroflex,do you mean Reloop RP TT's?
Hi Anil,
I had heard that the Sonodyne direct drive turntables (and perhaps HMV too) were sourced from abroad because the low volumes sold did not justify setting up manufacturing facilities in India. I have no idea which make was imported but would like to know.
Regards.
I think BSR made some TTs for HMV,Sony etc.They all were low cost and very low quality too.
Sachin
Insted of trying to solder about a thousand joints, why don't you buy WD40 and use the nzzle to spray it in the selector switches and controls?I mean the bass/treble/volume controls. AND if you know soldering WELL, then only, check out the large filter capasitors near the transformer and change them ...If they are dried out, you may damage your speakers as at some point the output stage transistors will emit a line frequency i.e. 50 Hz humm. can be bad for speakers if you happen to be playing music at loud volumes at that precise moment.
Guys, if you say so, but I have been using wd40 for many years and it really works like a charm in rotary selector switches and carbon track controls ( volume,bass,treb) And yes, it does leave a bit of parafinnic gooey mess but still, the sprayed control really works without the previous clicks or scratches.So why not try it?The compound you said, is not available in india so insted of risking speakers, I say use WD40.
Woow.... look at that. Aah... the cluster of eques ...... really romantic. How was the sound? How much did it cost? Is it still available? Just curious.....
Sent from my Nexus S using Tapatalk
Here is what i had during 1990's. here is the product brochure from Sonodyne, i still have the turntable. It came with Philips & Bolton drivers.
I own an Audio Technica Belt Driven TT with various magnetic cartridges. Have been playing this with my Bose Lifestyle 18 (version 2) with a Phonic GEQ 1500 (15 band GE). The sound really sucks with the Phonic GEQ at pass-through mode. The Bose suppresses most of the high and low frequencies and sounds pathetic. With the Phonic in action, it sounds little better. I used to listen to my LPs back in 1986-88 in my friends home who had a Sonodyne Uranus II. It sounded so beautiful - it as clear as crystal. All the frequencies were life-like. I wonder why Bose, such an expensive piece (of crap) can't deliver even 10 percent of that quality. Anyone experienced this?
Phonic GEQ 1500 is a 15+15 band Graphic Equaliser with independent channels (Signal Processors :: GEQ :: GEQ 1500 - Phonic | Manufacturing Quality Professional Audio Equipment since 1977). The Bose doesn't have a phono preamp, but the AT has a built-in preamp. Today I got a Sonodyne Uranus 2 amplifier (SA 580) with Graphic Equaliser SQ 500 and SX 909 speakers. Let me try connecting this setup to my AT and then I shall post a comparative analysis.what is Phonic GEQ 1500 (15 band GE). ?? is your bose has phono input? or Audio tchnica has phono pre built in?
Finally - thanks to this forum I found the deck I recall from my teen years...It was the K8...and it was made by Cosmic...For some reason I kept thinking it was sold by Beltek.
Clearly this was a deck that was imported and re-badged as Cosmic...Anyone know who the original maker was (most likely Japanese)...
And does anyone still have this machine?
Rajiv
Cosmic was famous for its re-badged cassette decks...mostly Akai!!
