Laptop to tv converter
andrewson00
madurai
how can i connect my laptop monitor to a normal tv
is there any converter available
in my laptop there is no hdmi port.
plz help ........
It depends on what type of laptop and TV u have. If you have a LCD TV and a laptop with VGA port, then just use a SVGA cable and connect both. Most of the LCDs do come with a VGA port. Its similar to connecting a projector to laptop.
thnks for ur reply i have lenovo laptop and normal 21" tv in my laptop svideo out is there when i connect it with svideo to tv out cable only black&white picture available,i try it with 3 different svideo out cable but nothing change , help me for a perfect any vga to tv out converter for me
As your Laptop has S video out,then S vid to video cable as suggested earlier should work.Now you need to lower the resolution in S video out,else it wont work.You need to check graphic settings in laptop too.
