New owner of Samsung plasma 43D490
I have set contrast to 80 and cell light to 15 after breakin ,is it all right to keep contrast and cell light high?
After a long wait i have purchased 43d490. Thank for hfv.
Pls share the setting for burn in period.
Shall i connect my usb 3d clip to wach now.
for first 100 hours keep everything 50 or below while watching tv channels. for watching movies you can just set it to movie mode.
What setting did u used pls share, i m fully confused about 4:3 16:9 and logo.
I m using dish tv what channel to watch,how many hours a day,what to avoid.
Maddy,
This is the setting I'm following
cell light=8
contrast=49
brightness=46
sharpness=0
And make the power saving Medium..
You can watch 3D... no problem your setting will be the same..
Congrats Maddy :clapping:..for the burn in period as recommended adjust your settings below 50.
Let us know your take about 3d experience.
@Maddy just change the channels a bit here and there .. Don't think too much into it.. Normally we change channels.. do it.. Try to see movies through USB sot hat you don't have to worry about the Logo this and that stuff.. Avoid new channels for some time
Maddy,
cell light=8
contrast=49
brightness=46
sharpness=0
Better keep power saving off. The PQ takes a hit if we switch on power saving mode.
there is no RCA out put for my 2.1 ch speaker.any option?
Use the Audio out 3.5mm..... for my case the left channel Audio comes in the Right channel for which i have to swap the Red and White cable while connecting to the external amp (2.1 Speaker).....
Let me know if you are having the same issue as well!
