rohitmusic
Urgent: Advice needed to complete my music setup!
Hello Friends,
Need expert advice on completing my sterio setup.
I have the Paradigm Monitor 7 speakers. Need to complete the chain.
Total Budget: 40k Max.
Requirement:
1) Amplifier
2) Source
My options:
1) Amplifier
i) New amp
ii) Pre-owned amp
2) Source
i) I have a DVD player
ii) Had an old CDP - but its lens is bad. Seems irrepairable.
iii) laptop
What will I be hearing of this setup?
- soft, melodious music, semi classical, instrumental, sufy, ghazals, AR Rahman, soft rock(80s), fusion, pop. Family will be listening to Indian film music as well - mostly the "good" "classic"/melody numbers
- Fav artistis: Hariharan, AR Rahman, All Indian classical instumentals (percussion and string instruments). I guess that gives some idea.
I basically like to unwind and enjoy the music.
How should I manage my budget for best audio experience?
Some thoughts:
1) This is my first HIFI setup.
2) Looking for long term solution (at least couple years minimum) Want to enjoy my music at my leisure
3) If I go pre-owned way then instead of only new amp I may also fit in a DAC in same budget?
4) I have already stretched my budget and it is more than doubled now.
5) I have hears some amps and I prefer a more open/vibrant, detailed and musical sound due to music preferences above.
Would appreciate some actionable inputs. And some probable combinations for the 40k budget.
Example: Try <this amp> + <this DAC>
I have been sitting on the fence and analysing but some actionable inputs will help make my setup take its first cry! :clapping: The speakers are lying in the living room inside their box pack for over a month now and its painful (understandably) to see them not sing!
Need help urgently! If you have ANY inputs please do share them with me. They will certainly help me! So, please let the inputs/suggestions/advice flow in!
Thanks in Advance!
Rohit
Music is full of silence and silence is full of music
Hello Friends,
Requirement:
1) Amplifier
2) Source
My options:
1) Amplifier
i) New amp
ii) Pre-owned amp
2) Source
iii) laptop
Some thoughts:
Thanks in Advance!
Rohit
