Digital output from Laptop without graphics card or sound card
SatSon
Chennai
Hope the question is clear from the title.
I have a Lenovo Z570 laptop which is not having dedicated graphics card/sound card. It is having only two audio jacks, one for Mic and other for Headphone/Line out. I have a Yamaha RX-V371 receiver and I would like to send digital audio to it, to make use of the DAC inside receiver.
I am running foobar and tried installing wasapi, but no luck.
[I have HDMI out in laptop, but didn't get chance to try as I don't have HDMI cable. But doubt if audio will work in my HDMI as I don't see HDMI audio device in my sound devices]
Check if the Z570 datasheet on lenovo.com mentions SPDIF anywhere? or open the audio properties on the laptop and activate digital out. see if you get a red light emitting from your headphone jack.
If either of the above work:
then what you need is a 3.5mm toslink to optical cable that would allow you to connect the laptop to the receiver. (If you already have a cable then a simple plug like this one would do: http://www.ebay.in/itm/120925366116...X:IT&_trksid=p3984.m1438.l2649#ht_2119wt_1143)
I don't have SPDIF in my laptop. :(
I think the next model with NVidea graphics has the same.
Thank You all...
I bought an HDMI cable today(from Ritchie street chennai) for Rs.250/-, they say it is Dell product, but don't know if it is genuine Dell.
And Yes, I am able to send digital audio signal to my 371 through HDMI and was able to hear the difference the moment I played the first song!
The audio device is shown as RX-V371 Intel display audio in my laptop
I played some DVD's as well, it is detecting both DTS and Dolby(it should detect anyways!)
So finally Happy,yes Yamaha has Burrbrown DAC which are superior to that of on board.Cheers.
Yes Spirovious. Extremely happy :ohyeah: as this does feel like an upgrade for me. I have been having SONY Hi-Fi's for years, so there is a major difference in SQ that I am able to feel.
I have been checking for Denon 1312 / Yamaha 371. I went through many online reviews and reviews in our forum as well. Obviously I have gone through your review of Denon 1311 & Yamaha 367.
And finally went for 371 as music is my priority, but can't afford a dedicated stereo amp now.
