Labor of Luv - 301
Gee John,
I've got a tonearm mounted on the motorboard itself and thought of an arm pod for another arm, but seeing your pictures I figured why not try an arm pod now itself? Then if I prefer the sound of an outboard arm pod I can simply cut my motorboard and make the squash ball plinth for the reduced motorboard size.
So thanks for the beautiful pics!
You should try make independent arm pod. To me the difference is quiet noticeable. It is very flexible also. if you go for a separate arm pod, you may not require to suspend the motor board.
WOW! Gorgeous :licklips:
Would love to have a listen, am sure the music sounds amazing.
BTW, does the record clamp really work/necessary with old TT's??? What is your opinion?
Enjoy
It's early days for me. I feel it tightens up the tones a bit !!
