Nitrous,
Hi and welcome. I am personally tired of answering this same question time and again. Please check/read through this forum for everybody's views on this topic.
Hopefully for the final time... As your budget is up to 40K add a few more thousands and go for PV8 42" plasma TV. If you still want to go with LCD and 32" only then again Panasonic/Philips are the best.
Guys,
I need to pick up a 32" LCD or plasma TV (which is better?).
My requirements are
1. Picture quality
2. Reliability (no glitches)
3. Build quality (longevity)
Budget is 30k to 40k
Hey moserw,
can u tell me where in hyderabad can i find panasonic PV8/PV80 at such cheaper prices?
i checked croma,jublee hills and he quoted 51990/55000 for pv8/pv80
ha ha! Chill,man!
Anyways, I already checked out the 42" panasonic discussion.
Let me see if I can do something about the remaining 10"![]()
Nitrous,
@madbullram: I'm not bent on LCD. If plasma is better ,then plasma it is
I'm working on the space for a 42" ,right now. If it works out, then its the PV8 ,else we go back to square one.
being one of the few flagbearers for Samsung PLasmas, please do check out the Samsung 42" A410 plasma as well, it's comparable with the PV8 (does better with HD, worse with SD), so it's at least worth checking out.
After buying a LCD ,do i need any other accessories? other than the wall mount?
any need of stabilizers?
never used 1 on any of my electronic equipments for last 20 yrs..
Also i will be using the 32 inch LCD for mostly TV viewing purpose. And will be going to check out ugadi offers soon.
model in my mind right now is pana 32lx800 ... any other LCD i can have a look at?
LG is on a LCD releasing spree... taking out new series every now and then.. any good model in LG i can consider against the 32lx800?
You would need the stabilizer, cables to connect equipment to the TV or through an AVR. Also, if you do not have a HT, worth looking into HTiB or AVR, stand for the TV if you aren't wall mounting,
Guys,
My requirements are
1. Picture quality
