Suggestion Need : LED TV Display with HTPC
YPS
Blr
Hi Guys,
I recently put APC UPS (Pure Sinewave) for my LED TV / HTPC / AMP / TataSky / Router, I noticed when I am watching HTPC Display on my LED TV and if there is High Voltage my TV Display goes blank for a second and comes back with resolution info box as right upper side, I am sure TV is not restarting as I don't see Samsung Logo which comes when i start TV.
Also i notice this only with HTPC not with TataSky Display.....
Any suggestion........Or seems my UPS not supporting LED TV but why this is not happening when TataSky is on ??
thanks
YP
check the power supply of the htpc
Hi cmsajith,
thanks for reply.....my HTPC is working fine and dosn't reboot when TV goes blank......so there should not be problem with Power Cable ?
thanks
YP
I am quite sure that there is a temporary break in the signal. So when the signal is back, TV is showing resolution dialog box.
Hi Just4kix,
We (Me & UPS guy) thought the same too as I had connected Anchor Spike and connected all Devices to that......today connected HTPC & LED TV directly to UPS.......lets see if this resolves the problem......:)
