Vcash
Hello Everyone,
I needed some advice on picking the right television for a dedicated HT setup. I currently live in the US and my parents live in India and are moving into a new house and I would like to buy them a TV for their media room has a house warming gift. I am buying the TV locally in India and have decided on a Plasma TV since this meets my requirements in terms of budget and technology needs.
Room
Let me describe the room first. The room is 10 X 8 and the viewing distance is around 8 Feet. There are large french windows on the right and a large sliding french door on the left so I expect the room to have a considerable amount of ambient light (Although this can be controlled with black out curtains). I have attached a diagram of the intended setup:
Viewing Habits
I expect that they will use this TV for only a couple of hours a day as this is the fourth TV in the house (Albeit the nicest one since the rest are Samsung LCDs that are several years old). Most of the time they will watch HD movies on this screen through a Blu-Ray player or a dedicated HTPC that I have setup for them. They primarily like to watch comedies and dramas. I can also see them using this room to watch sporting events such as tennis & cricket through a 720p DBS source. There is not much 3D content available on DBS or in their movie collection so I can see them using the 3D feature as a novelty feature only a couple of times. If 3D does become mainstream through DBS (Unlikely over the next few years in India) then maybe they would use it a bit more.
TV Options
The festive season has brought some nice deals to be had and I have shortlisted two televisions: The Panasonic TH-P50ST50D and the Samsung PS51E8000. As most of you may know, the top of the line E8000 just went through a major price correction and is now cheaper than the mid level ST50. I have gone through some reviews (Unfortunately I cannot go and view the TVs in person since I am in the US) and wanted to get your opinion on which is the better buy:
1) Panasonic TH-P50ST50D - Has very strong 2D performance and it comes with a 3 year warranty in India. The panel is said to be bright and vivid and the blacks are supposed to be fantastic. However, it is fairly expense for a "mid-level" plasma compared to the other makes in the market. Also, news of Panasonic stopping plasma production next year is a little disconcerting as I don't know what the support for the TV will be going forward. Having said that, this is still my defacto choice.
2) Samsung PS51E8000 - This was never in contention till Samsung slashed the retail price by almost 30% bringing the street price to below ST50 levels. 3D performance of the TV is lauded and since it's top of the line, the TV is loaded to the gills with "Smart" features including gesture and voice control, 2 remotes and four 3D glasses. Also, I think that the Samsung has a nicer design than the Panasonic. However 2D performance is not comparable to the ST50 and the blacks are not as black as the ST50 and it tends to attract a little bit more ambient light. Samsung also only offers a 1 year warranty on this model. However, having said that, the price and all the extras make this clearly value for money.
3) What about the Panasonic GT50 and the Samsung PS51E550 - At one point, I considered both these TVs (And still may depending on your responses). The only advantage that the GT50 had over the ST50 was THX calibration and a slightly slimmer profile. However it is 15% more expensive than the ST50 and from what I read, with good calibration, the ST50 can perform as well as the GT50. The E550 which is a Series 5 Plasma from Samsung was also being considered seriously primarily because of it's low price. The 8 series price cut has now made the perceived value saving seem less so than before and is only about 10% cheaper. Having said that, I have wondered if the 5 Series and the 8 Series use the same panel (Specs wise it looks like they do) and is the 10% premium for the 8 series worth it as you get rather gimicky smart TV features, a pair of extra 3D glasses and a slightly thinner profile?
Conclusion
So to sum it up, I am confused as to which is the best choice here keeping performance and price in balance. If the Samsung's 2D performance is not significantly different from the Panasonic ST50's, is it worth it to save the 15% and go with the Samsung. But on the flip side, if the quality is much worse in terms of sharpness, brightness and contrast - is it better to neglect the 15% savings and buy the Panasonic. The other question is around - Do you go with the manufacturer that gives you better warranty i.e. Panasonic or the manufacture that has a longer term commitment towards a technology i.e. Samsung?
And if you think either of these options are not right for the usage listed, please suggest other models \ technologies that you think may be a better fit.
Would appreciate some feedback that would help make my decision easier. Thanks for taking the time to read through this post.
P.S. My folks move into their house towards the end of next month so I am not in a rush to pick up the TV but would like to take advantage of a festive offer if any.
Room
Viewing Habits
TV Options
Conclusion
