Thad E Ginathom
One of the tweeters had deflated inwards. I made a funnel over the tweeter with my hand and inhaled hard. It worked! The tweeter is back to its normal shape.
The kiss of life re-defined!
They are a worthy successor to the Vienna Acoustic Beethoven Baby Grands. Not superior. Not inferior. Different.
ajay... move to an accuphase E450 or 460 if you decide to upgrade.
the 460 at its modest 180wpc is far more powerful than the Bryston 4bsst2.
shocking but true!
Nice write up Ajay. I demoed a very good 2 way bookshelf today as well in Bangalore...the Harbeth P3ESR...very natural, dynamic and balanced. Outstanding imaging. But of course, you must pay for these excellent qualities !
Not really, you can go for these - Continuum home
as per the designer, they sound better than the harbeths.
and if you have more guts, here's the diy version Continuum, Pr
Thanks! Where is B'lore are these available please? BTW just to mention that I have rarely come across any designer who does not believe that his system is better than some other
I am just looking for a small system for the bedroom and hence not spending too much time and effort - therefore the audition of the tiny Harbeths - my big system demands enough of me!
Just so I am not missing something, the Harbeths are available here in Bangalore but the Continuum need to be imported from the US?
Balanced IC with word sync is the way to go with Esoteric. No two ways about it Ajay.
Hi Prem, I think you are talking about balanced digital interconnect with word sync. Is it certain that AI-10 amplifier has a better DAC than SA-10 and using SA-10 as a transport is sufficient? Why not a simple balanced analog interconenct from SA-10 to Amp, using the SA-10 as complete CD player, in which case there is no need for word sync and any good amplifier will do, bringing Accuphase etc. into the equation?
AI-10 is supposed to employ the famous Esoteric Ring DAC, but i think so also SA-10 player.
Just curious to know if anyone has tried this out. I had looked at AI-10 amp since it had a built in phono, but the amp compulsorily converts all input to digital and reconverts to analog, which made me give it up as too complicated.
make it as 'good beginning'., your confusion and frustrations are understandable. I was in that situation until I met Mr.Pazani of Audio Planet, Koramangala, Behind BDA Complex, Bangalore. I suggest that you meet him, your search will end.
Best Wishes.
Kamalakannan
