Ok. What's the size of the MKV rips? I mean the ones that when compressed to DVD5 are better than retail DVDs.
its usually around 5gb.
I would say 4.3GB to 4.7GB to be precise. (4.7GB will have an additional language)
I normally remove this extra language using MKVmerge to make it 4.37GB and burn on DVD5 and store.
what do u do the mkv files? delete them?
Yes, I delete them. My friend stores all of them on HDD. So we can turn to each other in case of any problem.hyeah:
Yes, I don't use HDD anymore as I don't find them feasible, though I have about 1.5TB of movies on HDD. Rest all are on DVDs. I even split large movies into 2-3 discs. But this is individual choice. My friend is comfortable with HDD. He will buy new HDD when he's out of space. Between us we d/l about 9GB/day. Doing that for almost 1.5 years now. We use electronic timers to d/connect & connect modems and schedule IDM for free night plan. Meet on weekly basis to share movies.
Sloppy? No way!![]()
@frnd08 - Totally spot on. I've not moved to MKV/HD rips yet for the same reasons as not having h/w that plays MKV files. As of now its only DVDs and Divx rips on my Panasonic PV8 and Philips DVDP. This s/w will be useful for those who are collecting MKV rips but yet not able to watch them right now due to lack of h/w. I guess I'm not that future focussed to start ripping in MKV without even having the h/w for it. I will move to MKV when I get my WDTV/Divx 7 DVDP but then this s/w will be redundant.
I do see a use for this s/w in that I've 3 TVs but only 2 DVDPs that play Divx/Xvid and the 3rd being just a DVDP so I do need copies of my DVDs to play on the 3rd TV/DVDP combo (just so that my original DVDs all bought from U.S. stay secure and don't get scratched), but for this I find using DVD Decrypter to rip the DVDs and making copies of them easier than ripping and re-encoding with ConvertXtoDvd.
I was wondering why are you collecting MKV rips if you don't have the h/w for it. Guess you are future focussed...
Regarding collecting MKV rips, you can always back them up on DVDR and watch on your PC. With blank DVD's becoming dirt cheap, why think twice on backing up all your HD files?
@metalbandit - I'm just wondering how are you backing up the rips. Most of them are more than a DVD5 size? In fact some of the rips are going to 25-30GB and the average ones are 7-8GB. Dual layer DVDs and Blu-Ray are still not mainstream and also quite expensive. HDD is the only available option it seems. Unless you are collecting rips less than DVD5 size or are you re-encoding the MKV rips to fit them on a DVD?
after all there's no guarantee of the relase of DivX 7 enabled DVD players in the recent future, at least not in India.
Hey, you never know....
I still remember googling for DivX certified Pioneer DVD players around 4 years ago and they were available then, just not in India. And now, even the low quality brands have DivX/MPEG4 capabilities.
Moreover, if you already have a universal DVDP like the Pioneer 610 or Oppo or CA, then buying the WDTV makes more sense than the Divx7 enabled player.
I have converted some files using HandBrake; while the sound is perfect, the video is out of sync and lags behind the audio.
Is there any way to fix this?
