My New HT Setup
Yes, and make sure all the front 3 are at the same level. I see the center speaker put slightly behind the fronts. Let the tweeter levels be same for all 3 speakers.
Nicely done Ragav..
Once again it is proved the way of buying used system from members is worth + VFM and it is an good beginning for starters. Since there is every possibility we will end up in upgrading the system it is better to keep the packing stuffs in rack in order to pass it to next buyers to get an safe transit
Wow. Clean setup.. You could try to conceal the cables between TV and the cabinet?
The cabinet seems to be closed on all sides? No or less ventilation is quite dangerous.
Also I feel the fronts can be separated given the size of the hall and the viewing / listening position.
Nice
Could u tell me the prices of center and surrounds? For future reference.... I too own Paradigm Monitor7 V6 and go for the expansion.....
Sent from my HTC One X using Tapatalk 2
Ragav,
Wonderful looking setup. Very good use of the space next to the staircase leading up to the first floor.
You could try and add a carpet to the floor to reduce the reflections.
Best,
APK
