Yahoooooo..Bought the PV8 finally..
czarofchennai
chennai
Thanks guys...Finally bought the PV8 last saturday and it rocks.
Fully satisfied with the purchase and to add the snob value of owning a panel MADE IN JAPAN.
A small dampener but...The free Divx movie DVDs are not working eventhough my samsung DVD player is Divx enabled.
Suggestions pl.
:clapping:
congrats! Did you compare with LG TVs mentioned here on different thread?
Suggestions pl.
my panny says made :indifferent14:in singapore........
:rolleyes:
btw congrats....have fun with the display......run it for 100 hours on cinema mode with default settings for contrast brightness and color.
Suggestions pl.
Congratulation :clapping: Check if there is a Codec upgrade for your DVD player. Same happened in my Philips DVDp and I did a firmware upgarde from Philips site and it played well.
:rolleyes:.
Most of the PV8 we get are made in Singapore but the Panel in all Panasonic TVs (irrespective of where it is manufactured) are made in Japan.
mad - which dvdp you have and what was the last upgrade date? both 5986 and 5996 have very old updates!
regards
Have a Philips 4750 which is a HTiB :), just suggested to check if they have any new firmware updates which could help, wasnt referring to anything specific.
Bought the PV8 from J.D.Electronics...45000/-.
Thanks ram..will try the firmware updates.
Did not compare the LG.
Had enough opinions to rule out the LG.
VFM factor also had PV8 ruling my head and heart.
Suggestions pl.
:clapping::clapping::clapping:
how much did u pay for pv8
