rikhav
- Joined
- Mar 27, 2008
- Messages
- 2,674
- Points
- 113
Rudedawg might be able to help with cpu underclocking. I am not a windows guy so can't direct you precisely. You can google for windows overclocking tools and they might allow underclocking as well.
Hi Sid and Mowgli
It can be done through motherboard bios setup. Generally it's provided for overclocking which rud3dawg can explain you well
With the same bios settings you can under clock cpu and also lower the RAM clock speeds
I also am with Mowgli here that an under clocked I5 will have no issues processing flacs or any music file for that matter
