Hello,
I am trying to device a very basic vinyl cleaning bath. I am uploading some pictures of it.
Any suggestions in terms of modifications are welcome. I am using a nylon brush here. Is it proper to use that kind of brush ? Any suggestions regarding the brushes that can be used?? It is approximately 3 litres in volume.As a washing liquid just plane soap water should suffice or I need to use distilled water , isopropyl alcohol and some wetting agent formula.I have already collected a 500ml bottle of iso propyl alcohol. Bit hesitant to use it because of its ominus looks.:sad:
Thanks in advance,
Mahiruha.
Thanks in advance,
Mahiruha.
