yes, RO water removes/reduces minerals. it ought to be ok. its been recommended by many guys too online. or you could rinse using plentiful RO from the purifier and a final rinse with distilled to be safe
I wonder if even newborn babies are bathed with such care & consideration !yes, RO water removes/reduces minerals. it ought to be ok. its been recommended by many guys too online. or you could rinse using plentiful RO from the purifier and a final rinse with distilled to be safe![]()
Hello Stevieboy,
thanks for your suggestion. Today I will be getting some used LPS and definitely try it out on them. Just to double check are you pointing towards this.
3M India: Non-Scratch Scrub
Your hunch regarding the record cleaning bath is true. I was changing water every 5 lps just to get read of of the accumulated dust. Also there is another problem is how much detergent needs to be added to 5 litres of water to get a solution of even density. I need to research a bit on that. But every research has its own good outcomes also. I play lot of snooker and also need to clean the snooker balls. I find this distilled water isopropyl alcohol mixture does wonder to snooker balls they behave very well after cleaning.
Thanks,
Mahiruha.
tried something new last night. been having a niggling doubt that velvet is not enough to clean. so i got a scotch-brite non scratch scrub pad made by 3M. pink in colour with micro granule layer one side and sponge other side. used the granule layer to scrub the lp and man the difference is HUGE! the lps look cleaner and shinier and the sound is CRISP. if you've ever lived in the countryside and looked out after the first rains, you can see for miles and mile the air looks very clear cos the rains sort of wash away the floating dust in the air. its a very dramatic difference cos the air always seemed to look clear before. cleaning with the scotch brite pad was like this. i had cleaned ten lps before with velvet and ten with the scotch brite and i'm going back to reclean the velvet cleaned lps. its that big a difference.
the pad itself seems safe since no scratches happened. its nice and rough but not as rough as the normal dish cleaning pads. 20 bucks and its going to last for 100 lps at least.
i also apply cleaning fluid to the lps one after the other and soak them for 5 minutes then scrub.
Here is a picture of the cleaner next to my table. Quite convenient...clean and then play (sorry for the crappy iPhone picture):
Hi shaizada,
I am really thinking about taking the plunge with VPI classic along with this HW-16.5 cleaning machine. Can you tell me what sort of time does it take to clean a record beafore it is ready to be played. What is your satisfaction level with the quality of cleaning.
