Dear FMs,
I have been thinking of upgrading my RCA interconnects and Speaker Cables. I am exploring the option of importing the cables from US. I need to change my turntable RCA interconnects and need two more interconnects. I have shortlisted following cables:
For making RCA interconnects:
1) Mogami w2549, costs about 0.8 USD per feet.
MOGAMI
2) Mogami w2534, costs about 1.3 USD per feet.
http://www.mogamicable.com/category/bulk/microphone/quad/
For Speaker Cables:
1) Mogamai w3103 costs about 2.8 USD per feet.
http://www.mogamicable.com/category/bulk/speaker_cable/conventional_configuration/
I am planning to import the raw cables, buy neutrik connectors from India and then make RCA from them. I need your guidance/suggestion on following:
1) Are the selected cables decent ones or you would like to recommend something else in the same price range.
2) For the speaker cable, shall i get them terminated with any kind of sepcific spades or raw cables are fine.
3) if the termination with the spades is recommended then pls recommend the brand/model of those spades.
4) Anything you would like to add/recommend to above.
Waiting for your guidance/suggestions
Regards, Amit
MOGAMI
For Speaker Cables:
Regards, Amit
