Blue Ray under 18k
Nickhill007
Pune
I need a blue ray player with the following functionalities :
Integrated wifi
Playing 3d movies
USB should be compatible with almost all possible formats available on internet I. E. I would mostly play movies downloaded from the Internet (including 3d movies too )
Please suggest.
The requirements are better met by a media player like WD TV which is also cheaper at around Rs 6.5 k. Of course you wouldn't be able to play any disks unless you rip them into yourHDD
It can't play the blue ray disks right?? Can it play 3d content??
My LG BD670 does all you mention. It is wifi ready out of the box - updates itself wirelessly, automatically recognizes shared drives from devices connected to the same wifi network and plays from them, plays 2 TB hdd connected via USB (could play larger drives but i haven't tried), plays pretty much every file type, plays 3D (both disk and files), plays from youtube, picasa - you name it, it does it.
And when i bought it (a year ago), it used to cost 13k, could cost much lower now.
Thank you all bought the WDTV live for now at 7k with warranty and shipping will buy the blue ray to if budget permits in the near future :yahoo:
Thank you jagdish_p.
