john_k_antony
Guys,
All hell broke loose yesterday
. This is the second time it happened in my new home. Long story short - there was a bad voltage fluctuation and one of V-Guard stabilizers and 2 month old Emotive UPA-500 blew up
Here is what happened.
There seems to be a strange problem in my new house. Its a new layout with newly installed transformers and there are less number of houses now. I have 3 phase connection at home. Some times what happens is that when one of the phases has more load, the voltage in second phase goes up to 310V and voltage in third phase goes down to 150V. This happens random. I have no clue why this happens. This happened once earlier and that blew up my APC Backup Pro UPS used for my projector. The issue got resolved after the line man did some fix at the transformer. But yesterday again the issue happened and this time the damage was severe. It blew my V-Guard stabilizer protecting my APC Backup Pro -> Projector and then my 2 month old Emotiva UPA-500. I had my Oppo 105 and Emotiva XPA-200 in standby mode and some how they survived the abuse and they are working fine. Seems like MOV blew up in both the stabilizer and Emotiva. I have contacted the Emotiva customer support and waiting for their reply.
As per Emotiva recommendation, I connected the amps directly to the wall power socket. After this incident, I have connected all my equipment back to my Vertex 3KV audio grade stabilizer. I know it is not recommended, but I what else can I do with this crazy voltage fluctuation.
Now after 2 incidents, I am EXTREMELY SCARED to even switch on any gear in my home theater. I cannot enjoy anything as I am expecting a loud POP any time
. I desperately want help in getting this issue resolved. I would really appreciate if you guys help me with the following issues.
1. What is causing the occasional high voltage in one phase and simultaneously low voltage in other phase? How to fix the root cause?
2. Even if the above situation happens, how can I protect all my electronic equipment? I have a 5KV Vertex stabilizer connected to the phase that serves the lightings and fans in my home. So my house hold appliances and lights are protected. However for HT room, the power comes from a different phase and I have 15A sockets for connecting all my HT electronics.
Do some thing like the following help me with the situation?
Micro System Services | Power Protection | Homeguard
Would really really appreciate any help on this. I am really really desperate :sos:
Thanks,
John.
Thanks,
John.
