LOGITECH Z-5500 Digital
uttamagr
Hello,
PLease help me with LOGITECH Z-5500 Digital 5.1speakers.Is it worth buying.
Can anyone update me abt the pros & cons for this 5.1 system.
Its available for Rs,16,000 or 19,000 not sure abt the price range.
Its THX-certified, 505-watt power,
Hardware decoding:
Dolby Digital, DTS, and DTS, 96/24 soundtracks
Dolby Pro Logic II (Movie and Music modes)
6 Channel Direct
Stereo x2
Stereo
Supported digital formats:
Dolby Digital
DTS and DTS 96/24
PCM (uncompressed stereo): 44.1 kHz / 16 bit through 96 kHz / 24 bit
Total FTC power: 505 watts RMS
Sub-woofer: 188 watts RMS (into 8 ohms, @ 100Hz, @ 10% THD)
Satellites:
Left/Right: 62 watts RMS x 2 (into 8 ohms, @ 1khz, @ 10% THD)
Center: 69 watts RMS (into 8 ohms, @ 1kHz, @ 10% THD)
Rear Left & Right: 62 watts RMS x 2 (into 8 ohms, @ 1kHz, @ 10% THD)
Total Peak power: 1010 watts
Should I go for it or any other 5.1 speaker system in this price range.
can u review it for me.
Thanx and regards,
Uttam
They are PC speakers and sound as such. Way too much bass and very little detail otherwise. Useful for gamers more than anything else. Not really good for music or movies.
What is your budget and what is your primary usage going to be?
Dear Uttam,
I have the LOGITECH Z-5500 Digital Speakers connected to my DVD player thru the coaxial digital out.
I will give them 4 out of 10 for Movie Sound.They are not good 4 music.:sad:
Overall sound quality is bad.
I will not recommend them.
Francis
My budget is 16,000 -19,000.
can u recommend any other 5.1 for music and movies, compatible with my PS2.
Same is my opinion...
I knew an actual user who then moved to Onkyo 5.1 amp and a speaker set ( He bought my set) ...His opinion was same .....Movies sound not "natural" according to him .... did not ask about music...
Now he migrated from Brand new Z 5500 to partially used system for sound...
But if you b=need for gaming these are one of the best speakers
Also On Board DD & DTS Decoder with Digital Inputs...
From which part of mumbai u r?
Steatch a lil bit you have 3 options
1) Around 21-22 K yamaha AVR + Speakers ( with 6 Inch Active Sub)
2) Around 20 K Onkyo 3100 with passive sub
3) 25 K Harmon Kardon + Jbl with 8 inch active sub ( imho best combo)
also wait as differnt sale of eletronics just started .... so wait for vijay sales ads...
Meanwhile start visiting different stores
Hemanth has already listed the options. Is the PS2 going to be the only source or long term do you plan to use a DVDP or a PC?
:sad:HEllo,
I am a PS2 freak..
I play a lot of games but cant live without movies and music too,
plz plz advise
a good system well within 16-19k,cant go beyond this range:sad:
can any one of u throw a light on these yamaha 5.1 systems or any other system,how abt sony,any ideas.:)
with its specification and power out put
will appreciate u r efforts.:clapping:
coz the bottom line is
the system should rock in terms of music,movies and games.:yahoo:
Thanks to every one for their reviews..
thanks a lot again guys...
Uttam
