which internal dac is used by Marantz mcr510 and the internal dac used by NA6005
santosh4
which are the internal dacs used by the below and which is best:
1. Marantz MCR510
2. PM7005
3. NA8005
4.CD5005
and which has the best among all?
1. Marantz MCR510 ?
2. PM7005 Cirrus Logic CS4398
3. NA8005 Cirrus Logic CS4398
4.CD5005 cirrus logic CS4392
did not find anything on the mcr510. I can only guess that it may be a cirrus logic.
which is the best of them all ? I have read that the DAC chip is only part of it, there is an analog section, power and how they are implemented to consider and that specifications are not the only way to evaluate a DAC (important but not only)
edit:
1) from the article sidvee posted "Enjoy what you want however you want to enjoy it, and dont worry about how others do it. Just dont say your system is better than mine"
2) having said (1) IMHO the PM6005 (which I have, same DAC) sounded very good to me. Till I found something that *I* liked better. But the CDP6005 is the best, the internet says so. No idea don't know
ciao
gr
