anirban420
look out for an EEI CS2000 stereo ceramic cart. These had their own sound signature when wired to these old circuits. Believe me, when listening to vinyl, even the newer bollywood releases will sound good if you use one of these carts with your little amplifier. These were early designs and were conceived keeping in mind focus on a broader mid range with restricted lows and slightly rolled off highs.
reubensm, you will be happy to know that the only available stereo HMV cartridge available to that seller was the EEI CS2000. After you told me for that very cartridge, I thought it was not in my luck. But when I saw that cartridge I can not express how much happy and joyous I was :yahoo:hyeah:. Just grabbed that in a second. Also got the authentic Sealed pack EEI MX 20 Stylus. Here are the pictures of those.....
I want to know that pins of which side of the cartridge is connected to right channel of the amplifier....
I cleaned the Feet Platform with petrol to get rid of those molten rubber. And also cleaned the motor shaft with brush. Then I used iso-propyl alcohol to clean the area where motor feet are attached to the turntable base. These are now cleaned, weighting to join their service again....
Hope you also received the cartridge mounting clip with it.
This is a rare find. The CS2000s I have seen all my life were black or green ones. Your find could probably mean that HMV was sourcing carts from EEI and re-branding themCongrats on your find.
The cart looks pretty old. I hope the rubber cantilever support is in good shape (can't notice this clearly from the pics).
The motor itself looks like it would do great with an overhaul. However I must caution you against opening it unless you are very sure about your turntable skills.
The player used some obsolete type speaker terminals. However, these type of terminals were very common in cheap players made by HMV and PHILIPS in those days. My next quest was to change those terminals with a modern one. Thanks to the design engineers of HMV because I did not have to drill any extra hole to fit the modern type speaker terminal. I used existing two terminal mounting holes for this purpose ..... Here are the picture...
Hi folks,
Sorry for the late. I was so busy in the past couple of days I did not get time for logging in. Anyway, Back to the restoration topic.
After cleaning the motor and its "Feet", its now time to arrange some rubber grommet for two of its foot. I previously have mentioned that two grommets were molten and gone away. I knew that these original grommets are not available anymore. So, I searched total Chandni Chawk area to find a substitution of it. And I have got bad luck here. No substitution were found.
I came back home in a broken heart. When I was thinking of how to make a proper "jugad" of this thing, suddenly I saw a non-working rubber gasket of toilet cistern was lying around in my home. And i got my substitution of those feet. I just cut that gasket in desired size and used some metal washer and the Grommets were ready in a minute :yahoo: :yahoo: :clapping: :clapping:hyeah:
hyeah:
Here are the pictures of my "Jugad" grommet with the original one. See that height of all these are made same.
