Raspberry pi with Moodeaudio and Raspbian
srikar2011
Hyderabad
Hi friends,
I downloaded Raspbian and Moode img's. Can I have like dual OS's so that I select which ever OS i want I can select. If i copy both these images into Pi, will have dual OS's enabled? Is that possible in Pi? Currently I have NOOBS installed in my Pi.
Srikar
No 2 OS's on one SD card..and moode is slimmed down raspbian so why you need this extra raspbian?
How can I install Moode in Raspbian OS. Please let me know how to install.
Download Raspbian or Moode image from site. Use Win32 Disk Imager and burn the image on the SD card. Its the same as burning a CD or DVD.
YT instructions - https://www.youtube.com/watch?v=SdWr-aolCSA
If you mean dual OS then Moode itself runs on Raspbian so you can use Moode and still sideload apps.
Just to make that clear install Moode... then install other apps and s/w on it just like you do in Raspbian.
Anyone tried Moode over Raspbian? I am doubt it work.
For multi boot, use berryboot. It is very easy to install it. I was searching for berryboot image for moode but failed to find it. Also tried to convert image for berryboot but failed. At last I found runeaudio image and I am using it.
