Greetings everyone :
Since i heard a few reviews about the Allo PIANO 2.1 HI-FI DAC i decide to try it out.
I got myself the Vana Player from allo.com
Buying Experience : Staright forward and shipping to me reached in 3days. ( it was shipped from their Bangalore Office.) total cost around 10k
Packaging : Rock solid with all round good packing
Contents :
First combo test : Only Sparky and the Piano 2.1
Got the packaging out and began assembly, took 10 minutes to get the Sparky and the Piano connected. Inserted the Card , connected it to my TV via HDMI , attached a USB dongle for a Android keypad/trackpad. and powered it on via the given 5 volt power supply. A USb portable drive with music was attached to the USB 3 port. No separate power is required for the Piano 2.1, it draws power from the Sparky
The Screen came to life and i had a sigh of relief. Ubunto was up and running.
The Niggles mostly with the WIFI Stick
Wifi was not running though, neither was the device showing.
Ran the hardware tab and it was building a driver list, it then showed a wireless card and auto enabled it. The menu bar on top of screen then showed the wireless ICON. connected to my wifi network and it said i had updates did the update and it rebooted. Now wireless was gone again.. Connected to a Lan via network cable and mysteriously the wireless lan showed up again.
Now decided to play Music : Did the whole max2play setup etc. and tried to play a file and nothing.
Something decided to go corrupt and my screen froze.
Re-downloaded a new image from their site : Vana Max2Play Image v1.3 (Sparky)
installed it on a new SD card with the help of Win32DiskImager on a win 10 machine ( i had whole lot of trouble creating the bootable image on my mac)
Booted the new SD card and same wifi problems as before and same fix as before.
Configured the max2 play and the squeeze box server. Set the Plugequal in the advanced settings as the dac in the Squeezelite.
Then Played a flac song and voila music :clapping:
The sound was not that great, went back to the advance setting in the audioplayer tab and there was a Default plughw:CARD=PianoDACPlus. Saved and restarted. the sound was much better now. There is a marked improvement over my android tv box outputting digital to the Marantz PM6006. the sound is more natural sounding.
Next trial is with Volumio on the same setup .
Second Combo test will be with : Sparky , Kali and the Piano 2.1, I just wanted to see how much each of this makes a difference.
Do note, I have removed the Keyboard and the HDMI as all settings can be configured via the webpage
Pictures of the setup :
This is with a HD kept on top of the DIY console
The RC out connected via amazo basics 2RCA
The supplied WIFI dongle connected
On top of the Marantz PM6006
Do post comments if you have a similar setup and if i need do anything more.
Contents :
- Sparky
- Kali
- Piano 2.1
- Volt
- CM
- 5V Adapter
- Acrylic Case - Not really a case just bottom board and a smaller top board
- Risers, bolts
- Wifi Usb Dongle - Since the Sparky does not have any Wifi inbuilt- still a pain factors during configuration
- 8GB SD card with Ubunto for Allo
