Banana plug doesn't fit : Dali zensor 3
Can you pls elaborate when you say it doesn't fit in ? Thought they are standards ..
are you having some cap like you have in speaker terminals in AVR ?
Please remove the plugs from the speakers. The plugs will be a tight fit nevertheless.
Just posted an image
The issue is that the banana plug doesn't enter the speaker connector.
Not sure of the standerd size though.
I agree. It's a tight fit.
Just unscrew the connector at the back (as much as possible but do not remove it completely), it'll loosen up the gap.
Insert the banana plug (yeah still it'll be a tight fit) and then again tighten the screw.
Most speakers comes with a dust protection cap on the binding posts like this (Red & Black coloured) ...
Speaker Input Terminal Cup Insulated Gold Binding Post + Mount Screws - Paradigm | eBay
You should remove the caps to use a banana plug ... Any standard 4MM banana plug would fit. Few banana plug pics for sample .....
QED SCREWLOC ABS 4MM Banana Plug - 4 Pack - FutureShop.co.uk
5pairs 4mm Gold-plated Banana Plug connector for Speaker cable
20pcs 24K Gold Plated BFA-Z 4mm Banana Plug Dual Screws Speaker Cable Connectors
