My requirements were small : good quality stereo music experience with not too much bass and occassional movie watching. Had confusion in choosing between home theatre and stereo amp+components setup. Even took demo of very expensive HT setups. After reading through the Hifi Vision forum my confusion was cleared:clapping:, i decided to assemble the following components after research through other av sites also.
My Small Budget Home audio setup:
1. Stereo Receiver: Marantz PM 6005
2. Tower Speakers: Polk T50
3. Professional Tweeters: MCM audio
4. Source players: My existing Philips Blue Ray Player via Coaxial cable(amazon basics), Iphone and Ipod via imported swiss made stereo to RCA cable
[IMG]
[IMG]http://imageshack.com/a/img924/8900/cv7K9o.jpg
Results: Very good quality sound in decent budget(Rs 55,000):yahoo:
:sad:Drawback with stereo amplifiers: connectivity options like direct USB, Bluetooth, HDMI are lacking.
Final words: Component setup is far far superior to home theatres
looking nice, enjoy. how YOU integrate the tweeters with the polks,i didnt see any exteranal crossovers. if you want to run only high frequencies you may need HP crossover.
My pursuit..half way in progress, will be adding a sub and hdmi wireless extenders as the audio is sad to grab from projector to avr, can't run cables
Echo dot, Broadlink Rm Pro IR+RF blaster
Zone2: Mackie CR5BT, Philips 24" TV + Pi2
Inlight 8x6ft motorised screen
FireStick beams to big screen
Denon AVR-X3300W, All other stuff hidden in cabinets ;)
My LG 42" 3D
Dali Zensor 7
Hi, Guys, below is my current set up. I recently changed the rack to an Acrylic & SS racl . Its decoupled at the base with spikes and viscose rubber and at every level with viscose rubber.
cheers!
Anand
[/URL][/IMG]
STEREO: Transrotor zet 1 TT, Transrotor 8.2 MC reference phono stage, Ortofon rondo red cartridge, MSB Platinum iv DAC, MSB DATA TRANSPORT iv CD transport, mola mola Kaluga power amplifiers, Transparent audio Ultra cables and interconnects, Transparent audio premium USB cable, Transparent audio Reference Power cables Synology D 415 play 12 TB RAID NAS drive, Mac book air with Roon, Joseph Audio Perspectives Floor standers, Stillpoints Aperture Acoustic panels, Stillpoints Ultra mini isolators, Blue jeans CAT6a cables. Transparent Audio Power isolators MM2.
Hello folks,
Been browsing this forum for ages, my setup is below. I use a Onkyo TX NR 515.
Source 1: Gaming PC
Intel i-7 4770 processor
AS Rock Z 87 pro 4 motherboard
16 GB RAM
Micron 128 GB SSD for booting
AMD Radeon R9 270x 2GB DDR5 Graphics card: HDMI Output to AVR, DVI output to Monitor 1 and Display port to Monitor 2
Creative Sound Blaster Audigy SE sound card: Analog connected to Enbee ZX 80 Power amp and ZX1 Pre amp
Source 2: Tata Sky HD
Source 3: Onkyo UBT -1 Bluetooth USB adapter
Output Main: Optoma HD 25 LV Projector with manual drop down screen.
Output 2: Sony 55 Inch 4k TV
AVR: Onkyo TX NR 515
Front Channels: Elac FS 58.2 Towers
Center Channel: Elac CC 51.2
Surround: Elac BS 53.2
Surround Back: Elac BS 53.2
Sub: Elac 50 ESP
Sub 2: Using a Aura AST 2B-4 Pro Bass Shaker powered by a basic stereo amplifier attached to couch
Sound card analog output connected to Enbee ZX 80 Power amp and ZX1 Pre amp
Bose 161 speakers to add stereo width or as additional surround speakers connected to Enbee 4 channel Matrix decoder.
Output 3: Yamaha YAS107, to connect directly with the TV, but used mostly as a standalone bluetooth speaker.
igSkg5
jQE3ZQ
fQZRok
feMHuQ
Thanks everyone for the support and inspiration.
My Home set-up,
TV - Samsung 43H4900
AVR - Denon X1400H
Speakers - Pioneer S-RS3TB, Pioneer S-RS3SW, Focal Dome for Atmos
Inside the cabinet:
LG BD550 Blu Ray
Fire TV Stick
Chromecast v1
IOMega Screenplay Pro HD - 1TB
Chromecast Audio
Sony PS4 500GB
Videocon d2h (connected directly to the tv)
HTPC - CM 690 ii, Intel i3, 2120, 8GB RAM, 60GB SSD, GTX440 2GB GDDR5 (Placed in 2nd Bedroom, connected to Living Room via HDMI)
Storage: ~7TB (Including external and internal drives)
All controlled with Logitech Harmony Home Companion remote.
Network:
Primary - 2x Google Wifi
Secondary - TP-Link TL-R470T+, TP-Link TL-WR1043ND 300Mbps (Currently not used)
Samsung Smartthings Hub: 1x Door Sensor, 2x Motion Sensors, 2x Smart Plugs
2x Philips Hue Bloom lights
8x LIFX bulbs
1x Amazon Echo Dot in Bed Room
Cheap RGB light behind the TV (Controlled with Harmony Activity)
Raspberry Pi 3: Still setting up Home Assistant (Hass.io)
APC BR1000G-IN
Power Zone 650va - 80AH battery
Common DG ~500va (limit for each flat)
3+2 Recliner
More to come :)
My Home set-up,
AVR - Denon X1400H
View attachment 24945View attachment 24946
Inside the cabinet:
LG BD550 Blu Ray
Fire TV Stick
Chromecast v1
Chromecast Audio
Sony PS4 500GB
Network:
8x LIFX bulbs
APC BR1000G-IN
3+2 Recliner
More to come :)
LG BD550 blueray player can bit stream atoms movies from HDD?
It's the same with Sony Blu ray players, it plays Atmos which is available in the Blu ray discs but not from USB content. My ASUS O Mini, plays the Atmos content from the USB HDD.
Thanks & Regards,
Rajiv
Can they play normal dolby truehd? My understanding was that the player does not even come to know about Atmos being present. Only the decoder knows about Atmos if it can handle Atmos, otherwise it also just sees normal truehd.
On the BluRay it does not play normal TRUHD when files are played via USB. It does not have a bit stream option, only AUTO or PCM. PCM is always 2 channel audio unless AAC 5.1 is played. On the ASUS Media player there is an option to send the signal via bitstream even over HDMI. That is why probably the signal does not get to AVR without being detected.
Thanks,
Rajiv
