It is atmos clip i guess. Showing as true hd.
It is in sound auto mode. I am not good at thease settings.i am sharing andriod tv ,kodi settings. If i select movie mode then it is showing as true hd.
Let me known do i need to change anything.View attachment 25651View attachment 25652View attachment 25653View attachment 25654
Under audio settings in Kodi, if you scroll down, there must be an option of passthrough.. Enable it, if it is disabled...
Under mediaplyer audio settings, i think the current one is fine.. Also try HDMI..
Once you have completed the settings in your android device, restart both (incl AVR) and then play the same clip and observe what is displayed on AVR menu.. It should show only Dolby True HD..
If anyone has purchased Nvidia Shield TV 2017 in India at lesser than Amazon.in price (28K INR), please share the source and price. Tanotis website shows 25K INR but not sure if its genuine site, never used before and still price diff is big !. I want to buy it but the price difference is too steep in India !!!
Kodi passthrough enable. In AVR what sound mode i should select? Pure-> auto or movie-> true hd
Mi boxIs this images from Shield r some other media player?
Seems Mi box
Hi,Ok. And one more do we need subwoofer for Atmos setup.? Without sub it will be 5.0.2.
My 2 cents on Android boxes - NEVER EVER GET CHEAP ANDROID BOXES, YOU WILL BE CONSTANTLY SEARCHING FOR TRICKS TO MAKE IT WORK BETTER.
I personally own MI box ( Poor updates, but It does its job ). Plays DTS- HD 70gb files through kodi plex
You can buy mi box from aliexpress. It will take a month for them to deliver. but it has got better pricing. I bought it for 4.5k
Hello All,
(sorry if i sound dumb...)
Lets say we have an android TV box for around 3 to 4k
https://www.amazon.in/Profitech-T96...539030&sr=1-7&keywords=android+tv+box+mxq+pro
i guess we have to connect an external hard disc (containing br rips) to this tv box. Am i correct?
In such case we connect with an USB cable, but not a HDMI cable.
Will it still play 4K video and bitstream lossless audio??? ( i mean via usb cable)
Thanks in advance
Naveen
hi All,
With reference to the below two threads:
https://www.hifivision.com/threads/media-player-with-confirmed-dts-hd-ma-and-dolby-true-hd.13538/
It looks like there is no guarantee that budget media players handle lossless audio like TrueHD or DTS HDMA etc.
Unless someone who used them personally can confirm it.
But if BITSTREAM works with Kodi, we don't have to worry I am guessing???
I have the nvidia shield. It’s not comparable to anything in the market today. It’s less than 6 inches wide. The UI is super fast and easy to use. It’s an amazing all in one product. Yes it’s a lil expensive. But it’s worth every dime if u can get it. Rest all the media boxes will be a budget compromise compared to the shield.
