Wall Mount for mono price speakers
I have the following 5.1 speaker system
https://www.monoprice.com/product?c_id=109&cp_id=10906&cs_id=1090601&p_id=10565
I am looking to wall mount these and looking for a compatible wall mount. Here is the image of the back of the speaker
TIA for any help!
Hope you want to mount the center channel..
Either consider a 14 inch portable TV stand abt Rs 500/- from your local electronic store, where you would be able to place this speaker comfortably on it.. something like this - https://www.amazon.in/Royal-Look-Sp...qid=1518842099&sr=8-29&keywords=speaker+stand
(or) i think the speaker has mounting threads at the back.. You may consider a wall mount bracket from ebay.in for the same cost.. - https://www.ebay.in/itm/MX-2pc-Spea...086902?hash=item3f8fe4f6b6:g:tvkAAOSwFc5XwudU
Thank you very much. I do not intend to wall mount the center but the satellites have similar holes. i will take one of the speaker to SP road bangalore and buy the mounts.
Tono Systems (HT 55) have decent stands and wall mounts.....available on flipkart, amazon and rediff shopping...
Finally bought this from Mangalam Electronics, SP road Bangalore. Rs 300 per piece. TOTO was working out to be Rs2500 a pair. Thanks for eveybody who replied.
