OK. Did not consider those. Will putting a simple thick bed sheet on the TV screen reduce reflection? The glass door can be opened where the AV items are creating a cavity. Also they are at below 1.5 feet. Alternatively, can putting some cotton cloth like a thin bed sheet behind the OB baffle reduce the effect.Your wall unit there will mess up the sound completely. It’s got glass doors. Also your TV is there. As it is with a TL design you were having a huge problem. With the OB it will be a nightmare.
My wife overheard me when i was speaking with my carpenter on phone explaining him the OB design. After that, she gave me 3 choices with freedom to choose,Hari, if you need a cheap place to stay when your family throws you out, I have you covered.![]()
Dinner offered. BF& lunch at office.But in third option you will lose all sound you have !!!!!
Hey, it's Women's Day today - whatever they say they win!My wife overheard me when i was speaking with my carpenter on phone explaining him the OB design. After that, she gave me 3 choices with freedom to choose,
1 Me and the Mets stay.
2. Me and the OB stay.
3. Mets and OB stay.
If i select the 3rd option, will contact you for sure![]()
My initial suggestion was, since your driver is high Qts, just do make a test baffle just for comparison with your TL. With space constraints OB is no good and TL would be perfect.
Some people prefer to attempt TL only if driver Qts is between 0.25 to 0.4 Though I do not know if this rule strictly applies in practice.
Qts around 1.0 to 1.1 is ideal. If its over that then there would be a peaky response in the 50Hz to 60Hz region which cannot be tamed. Lower Qts driver tends to roll-off bit earlier and you dont get good bottom end.Is QTS the only parameter to be taken into consideration while building OB, doesn't extrusion (xmax) capabilities also matter (especially to play low end).
For low end duty, Qts on the higher side, say above 0.6 helps for flatter response. My little experience tells me, I would go for larger woofers, 15” preferably and with higher senstivity, above 95 dB. An Xmas of 3mm or above is sufficient. Consider the surface area being moved even at 3mm plus and minus. An Fs of 40hz or below is preferable. And there is no single driver which has all the cherries in it for OB low end duty starting with high Qts.
And OB dipole bass is different from sealed or ported. If done right, you can differentiate between diffferent drum beats.
You can try simulating the OB in a Basta simulator (download link in post #20 ). With that you can simulate vented, closed boxes and compare for yourself. You can try different driver Qts and check out the outcome.Trying to wrap this OB concept around my head. Cant this be achieved with a normal sealed or ported enclosure or better TLs or horns? AFAIK the only thing unique about OB is that the speaker is not mass loaded (contained in an enclosure) probably making the speaker sound as raw as it can (- the backwave). Is there something else that makes OB special (I have only built couple of OBs (that is when I absolutely had no idea on how to design it!) so pardon me for the lack of knowledge/experience with OB)
