DIY: Hi-Res Music Player based on Intel NUC + Linux + USB DAC
swamytk
Pune
Hi, recently I built a Hi-Res Music Player with support for FLAC/WAV/MP. I just used all old hardware lying idle with me. It is on top of Intel NUC, Linux, 1TB Hard disk drive and Fiio USB DAC. I have given my complete console logs to get it done as reference for others and myself too for future :-)
Hardware components:
1. Intel NUC 5i3RYH with 8GB RAM and 1TB Hard disk drive. HDD should have a small 30GB partition for / file system and rest goes to /home to store Hi-Res music files.
2. Fiio E10K USB DAC
3. Pen drive with Ubuntu Servver 18.04 Linux Installation image. I don't use Ubuntu desktop. It is a headless server without Monitor/KBD/Mouse.
Installation Steps:
1. OS Installation:
Install Ubuntu Server 18.04 using pen drive image and ethernet connected.
2. Wireless configuration:
$ networkctl
IDX LINK TYPE OPERATIONAL SETUP
1 lo loopback carrier unmanaged
2 enp0s25 ether routable configured
3 wlp2s0 wlan off unmanaged
$ networkctl status
● State: routable
Address: 192.168.1.20 on enp0s25
fe80::xxxx:edff:xxxx:xxxx on enp0s25
Gateway: 192.168.1.1 (NETGEAR) on enp0s25
DNS: 192.168.1.1
Only ethernet configured in above console log. So wireless to be configured
$ sudo apt install network-manager
$ nmcli dev wifi
IN-USE SSID MODE CHAN RATE SIGNAL BARS SECURITY
-- Infra 2 65 Mbit/s 74 ▂▄▆_ --
ssid1-5G Infra 36 270 Mbit/s 44 ▂▄__ WPA2
ssid1 Infra 2 130 Mbit/s 25 ▂___ WPA2
Now configure
$ sudo nmcli dev wifi connect <SSID> password '<Password>'
Device 'wlp2s0' successfully activated with 'd10a020e-32bd-4058-89ac-5e4ff1630a8f'.
$ networkctl status
State: routable
192.168.1.25 on wlp2s0
fe80::XXXX:edff:XXXX:XXXX on enp0s25
YYYY::f57b:YYYY:3803:YYYY on wlp2s0
192.168.1.1 on wlp2s0
DNS: 192.168.1.1
Wireless Done!
3. SAMBA server for File sharing (to copy Music files over network):- assuming you have a normal user called "audiouser"
$ sudo apt install samba
$ sudo smbpasswd -a <linux_user_name>
Append below snippet in /etc/samba/smb.conf
-------- start --------
[Music]
path = /home/audiouser/Music
valid users = audiouser
read only = no
--------- end ---------
$ sudo service smbd restart
Below cmd to check if any error in smb.conf
$ testparm
4. ALSA audio base installlation:
$ sudo apt install ubuntu-restricted-extras
=> installing media codecs
$ sudo apt install alsa alsa-utils
Note down
$ cat /proc/asound/cards
0 [HDMI ]: HDA-Intel - HDA Intel HDMI
HDA Intel HDMI at 0xaa124000 irq 46
1 [Audio ]: USB-Audio - DigiHug USB Audio
FiiO DigiHug USB Audio at usb-0000:00:1d.0-1.3, full speed
2 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0xaa120000 irq 47
Test from cmd line:
$ speaker-test -Dhw:1,0 -c2
Make the device default:
$ sudo vi /etc/asound.conf
defaults.pcm.card 1
defaults.ctl.card 1
$ alsamixer => adjust all volume for your card
$ sudo alsactl store
4. Hi-Res Music Player Daemon installation:
$ sudo apt install mpd
Edit /etc/mpd.conf => Here change media path directory as your music files and HW ID as DAC.
copy all Music files under /home/audiouser/Music => use same path in above mpd.conf file too
$ sudo service mpd restart
5. Install MPD client in Android/iOS and enjoy
Try the daphile player
Linux based
It's An OS by itself and is tailor made for music
Based on LMS
You will surely like it
And with that also try the Khadas Tone Board
Linux based
Based on LMS
Thanks. I tried all media Linux distros. I felt comfortable to maintain everything through command line and by hands on configuration. May be I can give try later on.
Thanks for introducing Khadas Tone board.
