Floor standing speakers
abhinavdora
delhi
I am searching for floorstanding speakers .
My usage is 80% of music and 20% movies/tv .
I have auditioned Dali oberon 5,Paradigm 3000,Qacoustics 3050,Elec debue 6.2 ,JBL A170 .
Out of which i liked Dali oberon 5,qacoustics 3050 and paradigm 3000.
Please help to choose one of the best or better speakers in this price range.
Abhinav Dora
Abhinav Dora
I'd recommend the Q3050i or Elac Debut 2.0 f6.2. The Q3050i is the upgraded version of the Q3050.
i have auditioned many floorstanding speakers ,QACOUSTICS 3050i,ELAC DEBUE 6.2,KEF REF,PRADIGM 3000 ,DALI OBERON 5,DALI ZENSOR 7 ,JBL A170,at last i have decided to go with DALI as it was too detailed,now i am stuck wheather i should go with ZENSOR 7 OR OBERON 5 as i am getting both for same orice
I think your choice is right way.. but my opinion if you little bit strech your budget then go for dali opticon 5..
Dali have a different sound compared to the Monitor audio.
So it comes down to your preference.
You won't go wrong with the Dali.
Good choice dear Dali speakers are really good/best among the same range of speakers.
Compared to the Zensors, the Oberons would be better with their new SMC Soft Magnetic Compound) technology which is supposed to reduce considerable distortion. The Oberon 5 has got excellent reviews as per What Hifi. But if you get a chance to audition the Zensors & Oberons personally then you could decide which one suits you.
Hello everyone, i am Rahul from Pune, new to the forum. @abhinavdora, have added Oberon On wall's as surrounds to my set-up (10 days back). They sound great, you wont go wrong with Dali's. Had been checking for Opticon 5 for front stage, but chose different (will be posting my combination soon). 5 or 7 both would be great.
