Wireless Keyboard Mouse for HTPC
hi ashish,
I see that 10m is the published number, have you tested it yourself. sorry, i've burnt my fingers before with the published numbers thats why I want to be doubly sure.
does it work thru obstructions or does it need a clear line of sight.
Most of the blutooth ones supposedly have better range, is that always true? IR and RF were hopeless for w/l kbd mouse at even 10-12ft.
thanx
I have personally tested it for 8-9 meters atleat and it worked like a charm and no it doesn't require a line of sight. The built quality is also very good. Blutooth works on the radio technology rather than the infra red one which requires the line of sight. I am using the same from last 1.5 years.
How about input lag? I did read somewhere that input lag of some of the BT based K/B mouse is a bit more than regular wireless. Did u notice any such issues?
Anybody's got the Logitech DiNovo Mini.:licklips:...
Like to hear about it since I was thinking of buying for my HTPC which I am planning.
for an HTPC, its an utter wastage of money. by the very nature of an htpc, you will be hardly using these input devices. Once you get a remote and a proper setup done, thats what u'll use most of the times. Its PC jewellery man, you can go for it for the 'show off' value though.
hey Doors,
:sad:
Actually, I was not planning for a remote operated cabinet for the HTPC, they cost a cool 6K extra than the ones without the remote. My home theatre is projector-screen type and therefore dark while the movies etc is playing and I understand that the "mini" has backlit keyboard. I rather use that 6k on a mini keyboard.:licklips:
Most reviews swear by the Logitech DiNovo mini for a Home theatre use though. I understand from the reviews that the product is small, easy to hold and also easy to use. Has bluetooth and can be operated from a long distance without it being in line of sight.;)
hey Doors,
:sad:
you can get a remote with a usb receiver for 1-2k. some of those might be backlit also. if you just get a receiver, you can use the harmony remotes with the htpc.
Hey, I've got a Harmony 525 with me:yahoo:...how do I use with a htpc or a computer? I think this one works with IR.
It will be great if I can use this one..Do I need to use any dongle and what program I need to install on the PC to make it work ?
I found one for 999/- shipped from ebay. Iam sure it can be got for upto 200 less from local stores (SP road?)
eBay India: USB PC Remote Controller for Media Center XP Control (item 260500968189 end time 03-Dec-2009 16:14:38 IST)
Here are the reviews of it in amazon. looks greatly positive. The second review (By C.Watson) points on how to configure it on harmony 880. I suppose procedure for 525 should be same.
Amazon.com: Wireless USB PC Remote Control Mouse for PC: Electronics
Looks like you need to get this for 1000 odd rupees, throw the remote away, connect the dongle to the PC and configure it using the supplied s/w and code it in harmony 525. As simple as that.
I was thinking of getting a wireless mouse for my laptop so that i use them as htpc, is the usb pc remote contol a good replacement for a wireless mouse? i will be playin mostly mkv rips thro mpc- home cinema or windows media centre. iam using win 7 pro edition. which one should i go for?
Logitech MX250 is a good option for Wireless keyboardmouse combo.Available at 1.25k in SP road. works smoothly from 10 m range without any glitches...a very good deal at dat price
Are u saying 10m?? Is it Blue tooth? no problems at all for pinpointing with mouse and typying with kbd? sound really good for that price.
