prateekatasniya
Oh..Coz he said he is looking for a 7.2.4 setup simple.
+1With such a healthy budget, all I would like to say is please take all the time in the world and evaluate all the suggestions given here. Read up the Home theatre section for further information. Do try and listen to as many brands as you can. It doesn't matter which is the leading brand, end of the day you alone are going to enjoy the system.
....This hobby rewards those who are patient... It's not about the gear or the brand or the budget, it all comes down to how we want to hear and see it.
Giving commercial cinema competition with a 65" TV?If you use this healthy budget wisely you may have a home theater system which can give a run to professional cinema setup in your city. You need to be informative and patient . You need to gather lots of information, suggestion and compile it with your needs. You need to invest some good amount of time to use money wisely to have great soundings HT SET.
Initially break your budget in small parts and look within that budget only. Else you will have some great components and other greatly compromised ones and the combo never sound great.
As you have dedicated room for HT setup , I advise to look for component specially designed for movies......
I may break budget as follows
1. Display unit - 1.5L
Within this budget I may consider 65" 4K LED/OLED TV with Dolby Vision and HDR10/+
Sony, LG OLED/4K LED
Projector if within budget
2. Source - 50k
Within this budget I may consider good UHD player and Apple TV 4k
Sony, Panasonic UHD player
Apple TV 4k for music and movie streaming
3. Room Acoustic - 20k
I may spend 20k on just Acoustic treatment which includes bass traps, rugs ,floor mat or anything within budget
4. Cable, Interconnects and plugs and dedicated power supply - 30k
Dedicated power line is also one of the important factor which usually gets ignore. Cables, interconnects and plugs have their own importance and which needs to be consider seriously. Balance between price and performance . If consider for concealed go for better shilded cable with sufficient gauge for longer life.
5. Subwoofers - 1.5 L
In dedicated room you may consider dual subwoofer setup. As most of the FM suggest it improve the total cinematic experience to next level. You may also consider more powerful single 15" subwoofer instead.
Seriously will consider dual XTZ 12.17 or single Rythmik 15"
6. AV receiver and Power amplifier
1L+1.5L = 2.5L
AV receiver alone can't deliver the power to all channels designed for desired spl. You need to consider a power amplifier for at least front three channels and rest low demanding channels may be handle by avr it self.
Will consider Marantz sr6014 or Denon AVR x3600 with 11 channels pre-out. Emotiva XPA- 3 as power amplifier if within budget.
7. Now you are left with .....3.5 L for 11 speakers .
It is easy and difficult to get great sounding speakers within this budget if you balance between them. I may spend 1.5 - 2 L just for front 3 speakers and remaining 1.5 - 2 L on 4 surround and 4 atmos speakers. ( Depending upon preference)....
I may seriously consider XTZ Cinema m6/8 for three front channels and XTZ Cinema m4 for surround and atmos. Mounting may he a challenge..... You may expect good amount of discount from XTZ dealer if you purchase full speakers set along with dual subwoofer from him. He may also help you to get remaining components in good price .
You may also consider SVS prime tower with SVS bookshelf/satellite and Atmos speakers for this purpose . SVS have great subwoofer series but little expensive than its competitors .
Audition is the key . Audition more than enough components till you get desired components within your budget...
Anything remaining from above budget, I will put into display budget
Hope this may help you little to take decision . Information and opinions posted by other FM is also important and valuable . Now you may be enough information to invest your money wisely.......Best of Luck
May be he meant to say interms of quality and For sure a 65 inch oled going to be way better interms of picture quality compared to projectors available within 2L. In a small room like mine it should work. But for OP I would strongly recommend to go for a projector set up since it’s a 16*15 room and with a budget of 10L he should be able to achieve a good set up. Also finding a good dealer and making all the purchase from him will help to get additional discountsGiving commercial cinema competition with a 65" TV?
20k for acoustics and that too including carpet for 10 lakh HT?
Are you sure a 65" TV can give cinematic experience?
Then why to buy projectors? Why projectors are sold?Dear FM , HT system is not just a display unit. Within the mentioned price he may get good picture quality display which matters the most then size.
Even I have seen more then 300 movies in projector screen but in the cinemas hahahaThen why to buy projectors? Why projectors are sold?
Did you experience 45° field of view? Or maybe even 36°?
I have seen over 300 movies on a projector screen..
And have compared it with high quality TV screens..
Field of view matters and it always will.. which is dependent on the size of screen and distance from screen.
Lol..Even I have seen more then 300 movies in projector screen but in the cinemas hahaha![]()
This was well before stepped in to HT. Past 5 years I would have seen hardly 8-10 movies in cinemasLol..
Then why is a home theatre needed?
Mate, just stumbled upon your post. You've been around here longer than I am (My knowledge/research still remains very much on paper)Have a question to experts. Need your help. Can the polk legend L800 be paired with a Denon x3600h or Marantz Sr7012 in home theatre setup and would they be able to drive the 4 Ohm speakers without going into protection mode. Do they need separate amplification or they will work at decent volumes. Don't intend to add any amplification if they are able to handle decent volumes.
Has anyone heard them and are they worth the price if available at good discounts.
Nominal Impedance Range | 2.8 ohms → 4 ohms |
Sensitivity (1 watt @ 1 meter) | 87 dB |
Don't pair up with AVR directly. Most AVRs are spec'd at 8 ohm.Have a question to experts. Need your help. Can the polk legend L800 be paired with a Denon x3600h or Marantz Sr7012 in home theatre setup and would they be able to drive the 4 Ohm speakers without going into protection mode. Do they need separate amplification or they will work at decent volumes. Don't intend to add any amplification if they are able to handle decent volumes.
