Buddies, Now What I am going to say will be probably very important to many of you who are trying to upgrade Subwoofers.
Trust me, Today I returned from the Demos of
XTZ 12.17 and
PB 2000 and
Rythmik L12R (The Guy didn't have Ported LVX12) and Ohh Boy!! What a Bassy Day it was...
Thinking I am one of the rare people who got the demos for the above three. XTZ/SVS on a proper Audi Room and Rythmik on a normal concrete flat floor like most of us.
And TBH, Movies were really good across All three with a bit advantage given to SVS maybe due to Ported and full loud bass. (One Port of XTZ was Closed for better mid Bass). XTZ and Rythmik performed equally good and almost close to SVS.
But..but... When it came to Music... All I needed was 1.15 sec of Drake (Ki Ki, Do you Love me) to identify the best for Music. The order was XTZ 12.17 > Rythmik LV12R >> PB 2000.
Again this made my decision much worse which i initially thought after the demo my decision would be clear..... But you know.
Now final set of my Queries are :-
1. I did't hear SVS PB 2000 Pro, The model that replaced 2000 with 50 Watt additional output and a new Amp Driver from Ground up. Should I wait for SVS PB 2000 Pro stock to be back to check the demo ?
2. XTZ 12.17 was coming around 96K and Rythmik LVX12 coming for 1L and PB 2000 around in Mid 90s. And there is a deal of rarely used PB 2000 Dual subs for around 1.5L (With Warranty of 4.5 years remaining, He rarely used for 5 months). So which is a better deal Money wise to performance wise fo 70:30 or 60:40 Movies:Music ?
3. The big badluck from Rythmik was the dealer didn't have the model I wanted LVX12 for the demo but the entry variant itself on a non acoustic treated room was decent enough. Not that impressed as I was with PB 2000 and XTZ where the demo was a properly dedicated Home Theater setup. Will that LVX/FVX 12 perform better than XTZ and PB 2000 ? And is the PB 2000 Pro better than all these ?
4. Rythmic goes lowest 14Hz to 200 Hz, but have the lowest power output of only 400W, XTZ goes up to 19Hz to 200 Hz but is a 700W powerhouse.
And PB 2000 probably sits best among them with 17Hz to 260Hz with 500W power. Does these statistics mean I will get a very good bass on lower volumes if the Output is More ??? Also for 26.2 X 11.2 Room with 3 outlets, How much power is sufficient for a single subwoofer. ?
5. I am planning to go Dual definitely at some point of time if the dual PB 2000 deal misses. In that case which one to get now ? As I understand most of you are against 2 different brand duals due to all the hassles of matching the frequency.
6. My opinion is of 2 choices as of now, Its very stupid TBH.
a) Buy the PB 2000 Duals from the deal at 1.5L
b) Buy either a Rythmik lvx 12 or XTZ 12.17 now and later add the other one. Please Note not the same subs for dual.
I want to get best of both worlds.
c) Wait for PB 2000 Pro and get that at the best possible price from the dealer.
So, Kindly answer from points 1 to 5 according to your best knowledge, guidance and experience.
And let me know your opinions on Point 6 a) or b) or c)
