Garrard 301 - New plinth
shafic
mumbai, India.
I recently made a multilayered plinth for my Garrard 301.
Used 20mm imported plywood.
I designed ( my own idea/design) to accommodate two different sizes of tonearms ( 9" or 12").
Final finishing is yet to be done. I am confused whether to go for paint or veneer.
Here are some pics.
Regards.
Beautiful Work @shafic bro...
It will be hard to bend the veneer at the corners. Paint it with automotive paint give it a mirror finish.
Thank you bro. Thanks for the suggestions.
Yes. Bend the veneer isa tough job. Automotive paint is an option. I have few ideas. Will share here.
You are our inspiration. You are doing some nice projects. We are learning from you bro. Keep it up.
Thankyou Bro...
