Subwoofer Recommendations 50k Budget
Long due update. I ended upgrading my receiver to the Marrantz 6014 and picked up the XTZ 10.17 from @Love4sound. I am now on the lookout for a center channel speaker with a budget of about 25k give or take. Based on inputs from @Love4sound and reading the forum, I have shortlisted the below:
  • Wharfedale diamond 220c
  • Emotiva C1
  • Q-Acoustics 3090Ci
  • Klipsch R-52
I did get a chance to briefly demo the Q-Acoustics 3090Ci. Appreciate your inputs.
Do you already have a LR or are going to purchase it on basis of the Center ?
I already own a pair of LR speakers (not a mainstream brand) which will be upgraded sometime in the future based on the center channel.
  • Emotiva C1
  • Klipsch R-52
As a user of Emotiva C1, I can tell it's a very good center in this category.
No worries of 4 ohm ,Ur Marantz 6014 will easily drive it.
You can also consider the Concept centre which is about 2.6k over your budget, the front LR can be then Concept 20/ Concept 40 as per your budget and needs. Perform really well for music and movies alike
