Hello There,Hi All,
I am looking for Universal all in one remote for home Theatre system - to control TV, media player, bluray player, DTH. Please share your experience & reviews too.
Hi All,
Thank you, will checkHello There,
If you have someone coming in from the US, see if you can get the Logitech Harmony 950 or the Elite. Here I think you can get the 650 for around 3k in Croma.
Som
ThanksHi Subbus,
Buy Logitech Harmony 650 Universal Remote Control (Grey) Online - Croma
Buy Logitech Harmony 650 Universal Remote Control (Grey) online at best prices from Croma. Check product details, reviews & more. Shop now!www.croma.com
I have used it before. It's a great remote but consumes batteries relatively fast. You can use rechargeable Eneloop batteries to sort that out. It generally works with most of the equipments but not sure about DTH boxes. Pls check if your devices are compatible before buying on the Logitech site.
Device Compatibility
Look for your television, stereo, dvd player or other home entertainment devices in the Harmony databasesupport.myharmony.com
Regards.
I had been using the Logitech Harmony 650 for many years. It's an easy recommendation. An excellent yet inexpensive option. Although the battery drains fast, in my experience. Unfortunately, a coffee spill made it less responsive and had to be discarded eventually. Later I upgraded to the Elite model that's serving me well these days. You can't go wrong with the harmony series regardless of the model you choose.
Good to knowI have been using Logitech Harmony 720 for almost 9 yrs which was brought from US back then for about $80 (Discontinued now).
Harmony are the excellent choice for universal remote.
okusing Harmony elite as well an its a great remote.
Alexa is supported but if you set your location as USA and download the skill.has anyone used harmony with Alexa/Google ? Is it supported ??
Me tooHi All,
Do we get it in India ? Any reference ?GE universal remote controllers have excellent reviews and are very economical
I see that they're available on Amazon.in, but at a much higher price.Do we get it in India ? Any reference ?
Okay, will check. ThanksI see that they're available on Amazon.in, but at a much higher price.
Hi @Nitin K i have looked at it on the chroma site it is not available.Hi Subbus,
Regards.
Hi Seker,![]()
Can you or any other fourm members help me getting this anywhere in india. I have seven remotes infront of me!!!
