External HDD not working with PS4 USB
prashant80
Ahmedabad
Hi all,
I got a 1.5GB WD external hard drive.When o tried attched to USB port of my PS4 its showing pop up that it snot formated as external drive.THough its working fine with my TV(TCLC8)
Please help
1.Shall i format as per the instruction in PS4
2.Wil lit delete all data as i have movies/songs etc stored on the HDD
3.is there any workaround without formating it.
"You’ll need to make sure your hard disk, SSD or USB drive is formatted using the FAT32 or exFAT file systems – the PS4 doesn’t support the NTFS file system. We recommend exFAT, because it supports files that are over 4GB in size."
