vaasu
Hello everyone, need your valuable guidance and suggestions to buy interconnects for my setup which consists of Oppo udp 203 Blu-ray player - Norge concerto 1000 stereo amplifier, pioneer fs52/mission lx2 speakers.
Though Off Topic, I would love to learn.I have send you a PM.
Thats something that was reported by Zerofidelity in one of his review on YT about the Crown. I haven't A/B tested it with an RCA cable yet but now that you mention it, worth checking out.Although I steer clear of "cable debate" as my pocket doesn't allows me to get into "cables", I do want to share one observation that I recently made and want to know views of fellow FM who are more experienced with them.
I recently got a pre-owned CA DAC Magic Plus, hooked it up to my Crown Amp, which were feeding a pair of Elac DB6.2
When I fed the amp through Balanced XLR (from UGreen), the sound was flat, not the good kind. The top end sparkle was missing, the low end grunt was absent. I mean I do like neutral sounding speakers, which err on the warmer side but this wasn't it. All while listening I kept fiddling with Volume control on the DAC to see if that brings up the bass but sadly it didn't.
Theres something very wrong with that. I have a chord mojo, which has a 3V output by default with headroom for more to be pumped out connected to the Crown XLS1502 through RCA and despite jacking it up beyond 3V on certain occassions, it has never clipped.On the other hand, when I used the RCA outs (using my homemade interconnects from 14AWG pure copper cables), the sound was much more livelier. It had everything, the bright top end, the punchy bass. The only Con was that when driven hard, the Clip light on the amp would come on while it never did when playing Balanced.
Any comment on my above findings would be highly appreciated.
One word, LOUDNESS!!!On another note, why do you push it beyond 3V? Thats quite high to begin with!
You mean the link out? Sorry, haven’t tried that one so no clue.One word, LOUDNESS!!!
While using XLR inputs, I selected the normal 1.44V sensitivity in the amp. For RCA's I used the .775V setting and the Clip light came on when the volume was cranked up (Bombay Theme), when Violins kicked in during the track after the Cymbal and Flutes, that's when it began clipping. Could be due to low-res of track too and it was a one-off instance in my listening test but as it stood out, I thought it was worth noting and mentioning here.
@DB1989 One query regarding the Crown Amps, the "Link" quater inch female receptacle, does it works with XLRs only or can one link through it even when using RCAs?
Yes. I intend to connect my other Crown amp using the same link out. Have already got the Quarter Inch TRS to XLR Male cables. The chain will be fully balanced this way. Read on AVS forum that when using XLR, the RCA is muted so I suppose the 2nd amp will get no signal through Link port if first one is fed input through RCAs. WIll be definitive only when test this out myself.You mean the link out? Sorry, haven’t tried that one so no clue.
Keep us postedYes. I intend to connect my other Crown amp using the same link out. Have already got the Quarter Inch TRS to XLR Male cables. The chain will be fully balanced this way. Read on AVS forum that when using XLR, the RCA is muted so I suppose the 2nd amp will get no signal through Link port if first one is fed input through RCAs. WIll be definitive only when test this out myself.
I am planning to get a crown. This maybe a silly question but just needed to clarify what kind of RCA cable should I get to connect it to the AVR?Yes. I intend to connect my other Crown amp using the same link out. Have already got the Quarter Inch TRS to XLR Male cables. The chain will be fully balanced this way. Read on AVS forum that when using XLR, the RCA is muted so I suppose the 2nd amp will get no signal through Link port if first one is fed input through RCAs. WIll be definitive only when test this out myself.
Any palpable benefits to biamping considering a single Crown has insane levels of power to begin with?Ran pair of RCAs from DAC to Crown XLS1502. Connected Stereo TRS Quarter inch cable to the Link Out and it's XLR Me end to the XLR input of Crown XLS2502. It works !!!
Be it RCA or XLR, whatever Signal is given to the amp, it passes on through the Link port.
Now will the same Link work with TRS to RCA cable, it probably would.
Thus allows one to use any kind of DAC/Preamp and still be able to connect multiple Crown amps, inclusive of Crossover corrections.
Hello ,
I had a useful discussion on cables with the owner of PSA audio . He guided me to speak to Blue Jean cables for a second opinion .
This is their take - Blue Jean cable's -
BTW - I still remain confused if the cables make a difference and what really do cables make a difference unless something defies laws of physics. In reality I am not blessed with superior listening ability .
Which Metals are the Best Conductors of Electricity? - Tampa Steel & Supply
Learn the order of the best-conducting metals from best to worst conductor here. Contact Tampa Steel & Supply for more information.tampasteel.com
Please don't bash as this is just an informed opinion of an Process control Engineer with 30 years of core process control maritime experience . We have not seen objective evidence in terms of gain in electron flow beyond subjective listening experiences that this is better when switched to a expensive cable brand .
We don't have silver conductors in an process control system where the modulation is in mini volts and mil-amps and more precise than listening experiences and far more objective in actual measured results.And the modulation is perfect to a "T " especially considering the distances are over 1 km and lightest error will deliver catastrophic results and loss of millions of dollars and billions in reputation and law suits . In reality I would stick to more of the c/s better theory for the current flow in line with established laws of physics .Better the gauge , better the performance and save your dough $$$ .Everything else is just gimmicks .
Thanks -
I agree with you on stuff from spectra cables. They do have some good stuff. I have used their products for years. Excellent connectors too. Their power cable is very good and so is their ofc interconnect(flattish/oval in dimension with excellent shielding.Re: Mega IC Shootout
In the interest of this post, please find links of good cables that can be purchased locally. I am replacing my earlier cables and will be using the 'Flacon super high conductivity' 22 AWG digital audio cables (its written on the cable) now for all my IC. I have purchased the gold plated RC male connectors from 'Spectra Electronics', Lamington Road, Mumbai around a year back and was using over the shelf cables till yesterday.
Audio Cables - Audio Video Cables, Microphone Cables and Speaker Cables Manufacturer & Exporter from New Delhi, India
Co-Axial Cables - Audio-Video Coaxial Cables, Rg-11 Coaxial Cable, Rg-59 FPE Pure Copper Coaxial Cable and RG-58 Coaxial Cable Manufacturer & Exporter from New Delhi, India
for other cable requirements you can browse the site.
The one i am using is DATA-017 in this link http://www.wireandcableindia.com/special-audio-video-cable.html
